F-Pace (X761) / C-X17 2016 - Onwards
View Poll Results: 2018 f pace crankshaft sensor
F pace crankshaft sensor
0%
0%
0%
0%
Voters: 0. You may not vote on this poll
2018 f pace p0366 crankshaft sensor code
Old Jan 19, 2025 | 07:34 AM
Dcorner's Avatar
Default 2018 f pace p0366 crankshaft sensor code
1rst code report. Changed sensor.
2nd code report. After changing sensor and swapping sensor. What can be the issue. The car starts every other start really rough and sometimes no issues.
Old Jan 19, 2025 | 03:37 PM
Robtrt8's Avatar
Year, motor and trim?
Have you been to the dealership?
How many miles on motor?
Old Jan 19, 2025 | 05:30 PM
Dcorner's Avatar
2018, 2.0t, f pace premium
no
120k
Old Jan 20, 2025 | 11:55 AM
Robtrt8's Avatar
I'm aware of 4 cylinder motors needing timing chain service up around that kind of mileage. Any chance that's what you're wrestling with?
Old Jan 21, 2025 | 07:14 AM
2018XF25T's Avatar
Have it check by an ASE mechanic.
Old Jan 21, 2025 | 03:39 PM
Battlehymn63's Avatar
You should have this checked by a professional.
As a Porsche/Audi tech this looks very similar to VVT CAM OIL CONTROL VALVE issues.
Could be a timing chain/guide issue too.
Old Feb 22, 2025 | 07:33 PM
Addicted2boost's Avatar
I just went through this on a customers 2018 4 cylinder (107k miles) AWD 2.0 gasoline Ingenium engine. We had performed a TSB pertaining to the solenoids on the rear of the cylinder head. Still had the P0366 code afterwards. My boss replaced both vvt cam gears, secondary timing chain, guides and hydraulic tensioner. Still had the same P0366 code after the repair. I was told to replace the main timing chain, both guides and hydraulic tensioner. I triple checked the timing of the primary and secondary chains along with the crank/cam gears position to make 100% sure that mechanical timing was not going to be an issue. *Still* had the same P0366 code afterwards. We had our off site tech support reset adaptations as it’s required (according to JLR) per their instructions. P0366 code was still there. I had performed an oil & filter change just after I did the main chain just an fyi. There was no sludge buildup inside the engine. After some more thought processes, I was scanning the procedures about the cam gears and I looked on the previous repair order and saw no parts mentioning the cam gear bolts. THIS was our fix.
You can see the location of the 4 holes has changed.
There’s a difference in there too.
Updated part number.
Is it possible that if one was to replace both the cam gear bolts with only the new bolts would the code clear??? 🤷‍♂️
You still need a very special set of timing tools, torque wrench *and* a specific degree torque wrench also. Keep in mind that all the timing components are at the rear of the engine. I forgot to include that oil passes through these bolts and is controlled by the solenoids mentioned earlier. Replacing these are not for a beginner. I hope this helps somebody.
santacruz11
Jun 29, 2024 04:38 PM
Kafj
Oct 7, 2021 09:47 AM
arthurharris2000
Jan 14, 2018 05:51 PM
