F-Pace (X761) / C-X17 2016 - Onwards
Battery Conditioner CTEK
Old Sep 11, 2020 | 09:34 AM
myer's Avatar
Default Battery Conditioner CTEK
I want to permanently connect my CTEK using the "comfort panel" (silly name!) in the boot space so that I can connect the CTEK conditioner without having to access the battery area. I have done this on my F-Type connecting the positive to the Bus panel above the battery and the negative to the body.
I have the instructions for the F-Type panel but not the F-Pace and the cables are different, does anyone have a photo and diagram for connecting?
Top
Old Sep 12, 2020 | 05:18 AM
myer's Avatar
Or alternatively the fitting / wiring instructions for the Jaguar charger
Old Sep 12, 2020 | 06:03 AM
JacksonvilleJag's Avatar
Just connect the pigtails directly to the battery terminals and run your lead out from under the floor cover.
Old Sep 12, 2020 | 09:07 AM
myer's Avatar
Default Battery conditioner
Thanks but I prefer to connect the positive to the Bus Bar as per the fitting instructions for the F-Type, unfortunately the wiring is different. I would like to have a copy of the Jaguar fitting instructions for the F-Pace. See photo of Comfort connector to be located in the load space.
Old Sep 14, 2020 | 01:27 AM
I haven't seen any Jaguar instructions for the F Pace. I'm not home, or I'd take a look and try to sort it for you, if in fact our batteries are set up the same. Connecting to the bus bar is for convenience only, as it is directly connected to the battery. My F Pace and F Type are connected directly to the positive terminal of the battery, and the same on my motorcycle. The CTEK connector is no different than any of the other battery charger connectors.
vet4scuba
Feb 23, 2026 03:50 PM
BRITDRIVER
Dec 4, 2022 01:31 PM
lpf4
Aug 27, 2021 09:48 AM
vika01
Mar 7, 2021 10:00 AM
Aussiejohn
XE ( X760 )
Jun 16, 2020 07:41 AM
