F-Pace (X761) / C-X17 2016 - Onwards
Engine Oil Viscosity vs. Oil Specification - STJLR.51.5122
Old May 27, 2025 | 10:35 AM
sjones813's Avatar
Default Economical alternative
Originally Posted by sjay
I prefer to service my cars myself and generally have looked at the owner's manual for engine oil specs when purchasing the correct motor oil for my vehicles. In reviewing the owner's manual I noted that the F-Pace requires SAE 0W-20 (synthetic) which is readily available at local stores by various brands. I did notice however that the manual goes further and says the oil needs to meet "STJLR.51.5122". Some of the Major Oil brands found locally do not reference this specification on the bottle. While I'm happy to try to find oil that is made to this exact specification (and will not just pour any oil in), I was wondering if anyone on the forum had any insight on what this specification actually means. Prior to the F-Pace I was typically using the correct viscosity/oil type and never ran into any problems.
Hi folks, I've been searching for proper oil for my [older] F-Pace with the 3 liter SC V-6, and found one. FRAM 0W-20 High Mileage Full Syn oil specifies that it meets STJLR 51.5122 spec.
Usually about $30-35 per 5 qt bottle. I haven't had it tested to compare with the Liqui Moly or the insanely expensive Castrol Professional from the dealer, but if they specifically indicate on the product that it meets the spec, it must. (Or you could litigate and take a bag of money from FRAM, which has the funds).
Just an option.
Ness925
Mar 29, 2023 12:14 PM
powxxl
Apr 11, 2018 05:28 PM
wyxtype
Sep 1, 2016 03:01 PM
Adam Lueb
May 8, 2012 09:11 AM
handychgo
Jul 29, 2009 11:19 AM
