F-Pace (X761) / C-X17 2016 - Onwards
Engines stops when I stop driving
Old Sep 14, 2021 | 05:15 PM
Denised13's Avatar
Default Engines stops when I stop driving
Why does the engine stop when I hit the brakes?
Old Sep 14, 2021 | 06:10 PM
2018XF25T's Avatar
First question: Do you see this somewhere in your dashboard? Auto Stop Start is enabled.
Old Sep 15, 2021 | 01:09 AM
JacksonvilleJag's Avatar
Old Sep 15, 2021 | 09:18 AM
Welcome to the forums Denised13,
It's to save the planet. More accurately, it enables vehicle manufacturers to comply with emissions and fuel consumption requirements.
The Stop/Start system automatically activates when the vehicle's ignition is switched ON. Unless required to support other vehicle systems, the engine switches OFF when the vehicle is stationary, e.g., at traffic lights. When the brake pedal is released or a drive gear is selected, the engine automatically RESTARTS.
Operation of the Stop/Start system is indicated by a green status icon in the instrument panel. See post #2. The system can be deactivated using button 30 and will remain in this state until you switch OFF the ignition.:
However, it will reactivate the next time you start the vehicle.
Old Sep 30, 2021 | 10:20 AM
uncheel's Avatar
Does the engine stop when you hit the brakes (your title), or when you stop (your description)? All of the above are correct responses if it's the latter, but if the car is cutting off before you're stopped, there's a problem.
Old Sep 30, 2021 | 10:34 AM
The OP Denised13 logged out 1 MINUTE after posting the question and has not been back in the 16 DAYS since then.
To save any more members wasting time and effort in replying - THREAD CLOSED.
bb_sam
Nov 5, 2021 12:45 PM
F-typical
Feb 5, 2015 12:16 PM
bollocsk187
Oct 22, 2014 01:14 PM
quartzjag927
Jan 22, 2012 01:54 AM
OhioXK
May 3, 2011 11:05 PM
