F-Pace (X761) / C-X17 2016 - Onwards
P2600 Coolant pump relay 'A' open circuit
Old Jan 16, 2023 | 08:57 AM
Hisue's Avatar
Default P2600 Coolant pump relay 'A' open circuit
Anyone knows where the coolant pump relay is located? Getting this OBDII fault but can't seem to find where the actual relay is located. Probably inside another component?
2018 F-Pace, 3.0 S/C
Old Jan 17, 2023 | 03:53 AM
82 Views but 0 Replies as as I write this.
Let me start by stating I don't have a 3.0 but I do have a 5.0 XK with the coolant pump and Jaguar tend to apply similar design across the model range so the XK description may help get you started.
The DTC lookup gives the same possible cause description:
There is only the one extended code for P2600 so no other codes or possible causes.
On the XK, the relay is in the Power Distribution Box. No reason to think F-Pace will be different. Not many relays on modern Jaguars so it shouldn't be too hard to spot.
Old Jan 17, 2023 | 04:27 AM
Hisue's Avatar
Thank you for the information. So far I checked the relays that are located in the engine compartment fuse boxes, all seem to be clicking. I bought a service manual which describes the coolant pump relay as R12, but unfortunately it only shows me a wiring diagram.
Old Jan 17, 2023 | 10:59 AM
My factory F-Pace Workshop Manual is equally vague about relay locations.
Veesixjag
Aug 14, 2021 12:20 PM
Richard87
Feb 12, 2021 08:20 PM
RedWolf82
Mar 7, 2020 03:44 PM
RedWolf82
Mar 3, 2020 05:45 PM
yeldogt
Nov 27, 2015 06:50 PM
