F-Pace (X761) / C-X17 2016 - Onwards
Sub-frame Rust Fix - Photos and Products
Old Nov 9, 2025 | 01:22 PM
Simonusa0's Avatar
Default Sub-frame Rust Fix - Photos and Products
The other day I dropped something down past the engine and into the engine/trans undertray necessitating removal of the tray to retrieve it revealing corrosion on the subframe from 8 years of Michigan salted roads winters. I decided I might as well fix it while I had the cover off.
Photos 1-4 in the collage are as follows
1. Corrosion as found
2. After grinding and wire brushing.
3. After application of Duplicator Rust Fix.
4. After 2 top coats of Krylon Rust Tough Protective high gloss enamel.
I recommend these products and hope they will offer protection for several years.
Old Nov 10, 2025 | 06:44 AM
2018XF25T's Avatar
Glad you've got that under control. Every spring (when snow is no longer at the forecast), spray with water via waterhose to remove salt stuck on that area and also every metal underneath to deter rust
Old Nov 17, 2025 | 07:04 AM
leadfoot4's Avatar
Another good product, one that has been on the market for a long time, is 'POR-15'.
(POR stands for "paint over rust")
Oliver94
Jul 16, 2025 03:45 AM
Bigcat2711
Jan 18, 2022 02:57 PM
Bikergonebald
Dec 23, 2020 05:49 PM
Phil1
Mar 9, 2020 01:48 PM
chris-jag
Jun 17, 2018 11:41 AM
