F-Pace (X761) / C-X17 2016 - Onwards
TPMS sensor reset 23 F Pace 250s
Old Jan 17, 2024 | 08:32 AM
Anna22's Avatar
Default TPMS sensor reset 23 F Pace 250s
Hi, l have a 2023 FPace 250S. The tire sensor went off and I adjusted the air pressure (was at 35 when recommended is 42? I set it at 38.5 psi. I have 2 questions:
Is 38.5psi good enough? I said okay to warning but light is still on. Service said keep driving and the light will go off, there is no reset button. Has anyone encountered this?
Thanks.
Old Jan 18, 2024 | 01:04 AM
You can change the TPMS parameters using the instrument panel menu.
Navigate to the vehicle settings and select light load.
Old Jan 25, 2024 | 07:13 PM
BritCars's Avatar
Yes. It will go off by itself. But why not use the recommended pressures? Better for fuel economy too.
Old Jan 29, 2024 | 08:30 AM
Anna22's Avatar
Thanks - that worked
Old Jan 29, 2024 | 08:32 AM
Anna22's Avatar
Well, they have a sticker on the door - that should be the recommended correct? That is 42 PSI, but the tires (per Jaguar were at 34 PSI). When I called and asked them which I should use, the said they recomment 33-36. So I asked why does the sticker say 42 - no answer.
What is it with Jaguar? I had an Audi before them. The sticker was the recoemmneded and the TPMS, once IiInfalated by tires, I would reset the warning myself on the panel.
Old Feb 3, 2024 | 08:36 AM
BritCars's Avatar
That sounds odd. The sticker is there for a reason and I use that. 33 sounds low...
The Land Rover models and I think the F pace allows you to specify 'light load' in the menu and use a lower pressure matched to the tpms. But I've never seen the point.
Old Feb 3, 2024 | 10:29 AM
SVR 575's Avatar
Go with 42 lbs., as stated you will get better MPG and crisper handling.
javalsu
Aug 4, 2025 10:16 PM
jasonc27
Feb 8, 2023 08:59 AM
2018XF25T
Jan 29, 2022 07:38 AM
Michael211
Dec 28, 2021 07:44 PM
hemlock
Mar 15, 2016 10:12 PM
