Wheel alignment specs
2020.0 F-PACE (X761), 204-00
SUSPENSION SYSTEM - GENERAL INFORMATION (G1946413)
SPECIFICATIONSVehicle Ride Height
NOTE:All figures are with vehicle at 'Showroom' ride height - full fluids, full tank of fuel, no occupants/luggage, tires inflated to normal pressures
DESCRIPTION MEASUREMENT MARKET FRONT/REAR NOMINAL MM (INCH) TOLERANCE MM (INCH) All markets except Brazil Front 484 (19.05) ±12 (0.47) Rear 485 (19.09) ±13 (0.51) Brazil Front 487 (19.17) ±12 (0.47) Rear 491 (19.33) ±13 (0.51) SVR Front 465 (18.30) ±12 (0.47) Rear 464 (18.26) ±13 (0.51)
- Ride height is measured from the centre of the wheel to the apex of the wheel arch, through the wheel centre line.
CAUTION:Both tie rods must be rotated by an equal amount.
ITEM LEFT RIGHT TOTAL/BALANCE Camber Nominal Tolerance Nominal Tolerance Nominal Tolerance Decimal degrees -0.38° ± 0.75° -0.38° ± 0.75° 0.0° ± 0.75° Degrees/minutes -23' ± 45' -23' ± 45' 0' ± 45' Castor Nominal Tolerance Nominal Tolerance Nominal Tolerance Decimal degrees 7.52° ± 0.75° 7.52° ± 0.75° 0° ± 0.9° Degrees/minutes 7°31' ± 45' 7°31' ± 45' 0' ± 54' Toe Nominal Tolerance Nominal Tolerance Nominal Tolerance Decimal degrees - - - - 0.26° ±0.20° Degrees/minutes - - - - 16' ±12'Wheel Alignment Specification - Front - Brazil
ITEM LEFT RIGHT TOTAL/BALANCE Camber Nominal Tolerance Nominal Tolerance Nominal Tolerance Decimal degrees -0.34° ± 0.75° -0.34° ± 0.75° 0.0° ± 0.75° Degrees/minutes -20' ± 45' -20' ± 45' 0' ± 45' Castor Nominal Tolerance Nominal Tolerance Nominal Tolerance Decimal degrees 7.42° ± 0.75° 7.42° ± 0.75° 0° ± 0.9° Degrees/minutes 7°25' ± 45' 7°25' ± 45' 0' ± 54' Toe Nominal Tolerance Nominal Tolerance Nominal Tolerance Decimal degrees - - - - 0.26° ± 0.20° Degrees/minutes - - - - 16' ± 12'Wheel Alignment Specification - Front - SVR
ITEM LEFT RIGHT TOTAL/BALANCE Camber Nominal Tolerance Nominal Tolerance Nominal Tolerance Decimal degrees -0.36° ± 0.75° -0.36° ± 0.75° 0.0° ± 0.75° Degrees/minutes -22' ± 45' -22' ± 45' 0' ± 45' Castor Nominal Tolerance Nominal Tolerance Nominal Tolerance Decimal degrees 7.16° ± 0.75° 7.16° ± 0.75° 0° ± 0.9° Degrees/minutes 7°10' ± 45' 7°10' ± 45' 0' ± 54' Toe Nominal Tolerance Nominal Tolerance Nominal Tolerance Decimal degrees - - - - 0.21° ± 0.14° Degrees/minutes - - - - 12' ± 8'Wheel Alignment Specification - Rear - All markets except Brazil
CAUTION:Both toe links must be adjusted by an equal amount.
ITEM LEFT RIGHT TOTAL/BALANCE THRUST ANGLE Camber Nominal Tolerance Nominal Tolerance Nominal Tolerance - - Decimal degrees -0.86° ± 0.75° -0.86° ± 0.75° 0.0° ± 0.75° - - Degrees/minutes -52' ± 45' -52' ± 45' 0' ± 45' - - Toe Nominal Tolerance Nominal Tolerance Nominal Tolerance Nominal Tolerance Decimal degrees 0.10° ± 0.10° 0.10° ± 0.10° 0.20° ± 0.14° 0° ± 0.14° Degrees/minutes 5°9' ± 6' 5°9' ± 6' 12' ± 8' 0' ± 8'Wheel Alignment Specification - Rear - Brazil
ITEM LEFT RIGHT TOTAL/BALANCE THRUST ANGLE Camber Nominal Tolerance Nominal Tolerance Nominal Tolerance - - Decimal degrees -0.72° ± 0.75° -0.72° ± 0.75° 0.0° ± 0.75° - - Degrees/minutes -43' ± 45' -43' ± 45' 0' ± 45' - - Toe Nominal Tolerance Nominal Tolerance Nominal Tolerance Nominal Tolerance Decimal degrees 0.10° ± 0.10° 0.10° ± 0.10° 0.20° ± 0.14° 0° ± 0.14° Degrees/minutes 5°9' ± 6' 5°9' ± 6' 12' ± 8' 0' ± 8'Wheel Alignment Specification - Rear - SVR
ITEM LEFT RIGHT TOTAL/BALANCE THRUST ANGLE Camber Nominal Tolerance Nominal Tolerance Nominal Tolerance - - Decimal degrees -0.88° ± 0.75° -0.88° ± 0.75° 0.0° ± 0.75° - - Degrees/minutes -53' ± 45' -53' ± 45' 0' ± 45' - - Toe Nominal Tolerance Nominal Tolerance Nominal Tolerance Nominal Tolerance Decimal degrees 0.10° ± 0.10° 0.10° ± 0.10° 0.20° ± 0.14° 0° ± 0.07° Degrees/minutes 5°9' ± 6' 5°9' ± 6' 12' ± 8' 0' ± 4'
As a follow up to my initial question, I was asking for the '20 specs because my "indie" shop didn't get the updated specs from Hunter Engineering yet, and I wanted to get an alignment check done on our '20 F-Pace. As it turns out, the '20 specs are the same as the '19 specs.
burmaz
Jul 1, 2013 06:59 PM
