2015 F-type spot a S from a Base model
Old Nov 5, 2020 | 09:32 AM
Valter Fernandes's Avatar
Default 2015 F-type spot a S from a Base model
Hello.
I'm new to the brand having owned several sports cars before.
I'm very excited about my imminent purchase of a 2015 F-type Convertible.
The car is a 3.0 V6. How can I visually check it's a S or a Base model? Apart from the badges obviously.
Different digit in the VIN? Any cues?
SAJAA65B7F8K21735
Thank you!
Valter
Old Nov 5, 2020 | 04:08 PM
OzXFR's Avatar
The easiest way to tell from the outside without any badges is to check out the front brakes.
The S came standard with the larger 380 mm front brakes and the base came standard with 355 mm front brakes. The calipers and anti-rattle clips look similar but they are different and once you become familiar with the different appearance you can pick 'em a mile away.
Trawl through the various brake threads and you should find some pics of the two different front brake set-ups.
Of course that little trick won't work on a base which has been optioned with the bigger brakes but I would hazard a guess that is/was extremely rare.
Another way to tell is to check out the engine bay (if you can), the S came standard with adaptive suspension and the base did not, a car with adaptive suspension will have wiring plugged into sockets on the tops of the front shock mounts and a base will not. I don't think adaptive suspension was an option on a base but I stand to be corrected!
Edit - the picture post thread is probably a better bet for finding decent pics of the different front brakes: https://www.jaguarforums.com/forum/f...-thread-86517/
deco87
Oct 2, 2021 06:50 PM
SJ Bayer
Apr 17, 2020 10:21 PM
Bonz
Oct 8, 2019 05:18 AM
Dogbreath!
Jul 11, 2016 07:56 AM
spectremotorsports
May 6, 2014 11:12 AM
