2018 jaguar f type 400 sport code p0128 only with 18000 miles check engine light on
My 2018 jaguar f type 400 sport only with 18000 miles got check engine light on not blinking. I got it scanned and I got code p0128 . The car is not driven often weekend car. Can I get some possible causes. Code po128 says coolant thermostat(coolant temperature below thermostat regulating temperature)
I had a similar issue with my MY15 R, RWD. Here's a link to the thread when I posted earlier in 2024: https://www.jaguarforums.com/forum/f...6/#post2818388
Short summary from mechanic who fixed it:
"We found the temp sensor wire was rubbing on the power steering pulley, we repaired the wire and re routed wires, test system and everything tested ok"
Be interested to know if your fix is similar once you get it resolved
Kennedy
May 11, 2010 10:20 AM
