2021 F-Type R Coupe Tire Replacement Size
Old Nov 8, 2022 | 12:33 AM
KenFtype's Avatar
Banned
Default 2021 F-Type R Coupe Tire Replacement Size
My OEM summer tires are 305/30/20 rear and 265/35/20 front on my 2021 F-Type R Coupe. I have an almost new set of 295/30/20 rear and 255/35/20 front UHP all-seasons from my prior 2018 F-Type R convertible. Tire Rack says that the smaller size tires are an acceptable option for my coupe. Anyone disagree and, if so, why? Thanks!
Old Nov 8, 2022 | 04:34 AM
Robtrt8's Avatar
I use the tire size calculator on 1010Tires.com whenever I'm comparing sizes. https://www.1010tires.com/Tools/Tire-Size-Calculator
Old Nov 8, 2022 | 05:14 AM
scm's Avatar
scm
The "smaller" size used to be OEM spec for earlier Rs - only the SVR had the larger size. If the wheels haven't changed size for the new R you should be fine with either size. Make sure the tire load and speed ratings are suitable for the new R, though.
Old Nov 8, 2022 | 07:18 AM
KenFtype's Avatar
Banned
Thanks. At 575 hp, mine is successor to SVR. The speed ratings should be ok.
jcb-memphis
Mar 5, 2024 01:35 PM
GranTurismo01
Nov 14, 2022 11:16 AM
Luca M
Apr 7, 2022 02:13 PM
myironlung
Feb 20, 2022 07:04 AM
jag_guy_2020
Jan 12, 2014 11:18 PM
