2022 F-Type R - uses 1 quart oil in 1st 6000 mi.and dealer can’t find leak
Old Oct 16, 2022 | 09:27 AM
  #41
Dwight Frye's Avatar
We realize that this ordeal has been frustrating for you. But at least now it sounds like your dealer is following a rather standard procedure to determine oil consumption, i.e. starting with a known amount of oil in the sump and then measuring again at fixed intervals (and hopefully under exactly the same conditions) to determine how much oil is being consumed.
I will assume that they have really ruled out any leaks since you didn't mention if they added any UV dye to the oil. But.....just to satisfy myself if it were my car, when you take the car in for the first check, I would ask the technician to put the car up on a lift and pull all of the underbody aerodynamic cladding off and do a thorough visual inspection for any oil that may be places it isn't supposed to be.
They may have been lazy and just assumed that the oil is being burned rather than leaking somewhere. It may not be a big enough leak to leave a telltale puddle under the car. But enough of a leak that it goes through 1 qt/6000 miles.
Good luck and keep us posted as you go along.
Old Oct 16, 2022 | 10:06 AM
  #42
F-type-r-2022's Avatar
Thank you. They said they did do a thorough inspection for leaks (no dye).
Old Oct 16, 2022 | 01:28 PM
  #43
eeeeek's Avatar
Originally Posted by F-type-r-2022
UPDATE. UPDATE. UPDATE. UPDATE
Dealer drained the oil and measured then added more oil and they are going to measure every thousand miles to monitor any future oil loss.
Out of curiosity, how much oil did they drain out?
Old Oct 16, 2022 | 04:14 PM
  #44
I don’t know, but they have a record of it. But I had to add 3/4 quart just to get it to the shop. I provided the oil bottle and photos as I was not gonna drive the car with it being a quart low.
Old Oct 16, 2022 | 04:24 PM
  #45
CJSJAG's Avatar
Was 6,000 miles the first time you noticed the low level and needed to add 3/4 qt to drive it to the dealer?
As I posted earlier. my oil "consumption" stopped within a couple thousand miles.
Perhaps (hopefully) by 6K, the problem has already solved itself.
It sounds like your dealer is treating the issue fairly, and presumably you are monitoring the oil gauge..
Old Oct 16, 2022 | 08:18 PM
  #46
Yes, as it was the first 6000 miles of ownership of a new car.
crashxx
Dec 16, 2024 09:58 PM
ExcelsiorZ
Sep 14, 2024 08:57 AM
probert5
Feb 5, 2022 02:59 PM
crisd2011
Aug 5, 2020 05:53 AM
markbridge
Apr 8, 2016 10:53 PM
