access to luggage compartment
Old May 25, 2015 | 03:47 PM
dtwills's Avatar
Default access to luggage compartment
I am brand new to this forum.
Recently I disconnected the battery because I needed to store my F Type for several months and I did not want the battery to discharge over the storage period. After disconnecting the battery, I inadvertently closed the luggage compartment hatch. Now car electrics are off and I cannot get back into the luggage compartment to reattach the battery. I was able to open the door with the emergency key in the smart key, but it did not unlock the luggage compartment. How can I get the luggage compartment open?
Old May 25, 2015 | 05:13 PM
Stohlen's Avatar
Try to use another battery connected to the positive terminal under the hood and a ground. This should power the vehicle unless jag does their wiring funny.
Old May 25, 2015 | 05:25 PM
Unhingd's Avatar
If you don't have a spare battery, you can also use a regular battery charger (not a trickle charger) to provide enough juice for the accessories.
Alternatively, if the rear compartment cover is not in place, you might be able to reach back with some kind of hook to snag the emergency release.
Old May 25, 2015 | 09:38 PM
DJS's Avatar
DJS
+1 this is what Jaguar recommends. Use jumper cables to the jump point under the hood (by the engine).
Old May 25, 2015 | 11:46 PM
dtwills's Avatar
Thanks, Stohlen, Ihoboy and DJS. I will take those suggestions on board and give them a try.
SD96XJ6L
Dec 27, 2025 09:58 PM
Poet
Feb 7, 2025 02:18 PM
philwarner
Jan 31, 2016 09:36 AM
convincor
Oct 1, 2015 05:19 PM
