Active Exhaust
Old Oct 25, 2022 | 12:34 PM
CJSJAG's Avatar
Thanks all for the inputs.
Just had the dealer check it out. Apparently the valves are operating normally!!
So, while the exhaust still sounds good to me, I still cannot distinguish a difference whether the switch is activated, or in dynamic mode, or the fuse is removed - no matter how hard I push the accelerator.
So, not unhappy with the sound, just not able to tell the difference, and a bit baffled. My cat growls pretty good regardless of driving mode. It occasionally pops at start-up.
BTW I am not hard of hearing or unable to distinguish different notes or volumes!!
Still, have to love the growl.
Old Oct 25, 2022 | 01:30 PM
Jag Bass's Avatar
That is strange. It is dramatically different with valves closed vs open on the V8.
Old Oct 26, 2022 | 10:00 AM
cpq100's Avatar
Have you tried listening to another 2021 to see if it sounds like yours?
Old Oct 26, 2022 | 10:33 AM
CJSJAG's Avatar
I wish I knew somebody with a 2021, but alas no.
F-Types are few and far betwen here, though ironically there is an identical 2022 (BRG vert) 8 cylinder P450 that shows up from time to time just a mile away.
I have yet to catch the owner to speak to.
I may try to record my exhaust sound at different settings and post back.
Old Oct 26, 2022 | 10:41 AM
cpq100's Avatar
Maybe there is one on a dealer lot nearby you can listen to?
Old Jan 11, 2023 | 04:03 PM
CJSJAG's Avatar
Took the car in for its 24 month service and asked again for the active exhaust to be checked.
I still am unable to detect any difference between regular, dynamic mode or depressed active exhaust button.
Unlike the previous check whe it was declard "normal", this time a code was identified with initial diagnosis of failed solenoid.
So, new solenoid is on order for fittig in mid March.
Trouble is it may be a case of "be careful what you wish for" , "leave well enough alone", or "first do no harm"!!
The car sounds great right now - presumably because the exhaust is open continuously.
I just feel like it should work the way JLR intended but may miss the growl in the future once it is fixed.
I guess I shall just have to depress both the eco stop/start button and the active exhaust button whenever I drive!!
Old Jan 11, 2023 | 04:14 PM
Thunder Dump's Avatar
Well if they end up fixing it and it's too muted, even with the switch on, you can always pull fuse #15 again and it'll be as loud as you have it now, since you didn't detect any difference between the two.
Old Jan 11, 2023 | 04:23 PM
  #28
CJSJAG's Avatar
Yes - figure at least I will know
Beginner
E type ( XK-E )
Jan 26, 2022 10:43 AM
LifesAnesthesia
Dec 29, 2021 09:26 PM
CHEVEZZZZ
Dec 14, 2017 01:31 PM
Simran Singh Randhawa
Dec 14, 2016 01:06 PM
Mark99
Oct 12, 2016 01:47 PM
