Affordable Flow-Formed Wheels for your F-Type: VelocityAP Partners with APEX
Old Mar 1, 2023 | 02:01 PM
  #81
Stuart@VelocityAP's Avatar
Sponsor
Originally Posted by ToysARs
I personally would not want fronts to be more tucked in than the rears especially if you consider the the fact that the added negative camber in the front would emphasize the "tucked-innes" even more. Just my 2 cents
Good to know. Would you consider it if they came with a 5mm spacer?
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Mar 1, 2023 | 02:27 PM
  #82
GeorgeIII's Avatar
Originally Posted by Stuart@VelocityAP
So, if we offered a +10, +16 versus +16 front and rear and that was the only option, would that stop you from buying if you otherwise liked the price & spec of the offerings?
I would be in.....
Old Mar 1, 2023 | 03:55 PM
  #83
TheDrainPlug's Avatar
Hi Stuart,
I'm pretty new to the forums, and only had my F-Type for a little over a year now, but would be interested. A visual would go a long way to making a decision!
Old Mar 1, 2023 | 07:39 PM
  #84
ToysARs's Avatar
I would prefer not to. If I'm buying aftermarket wheels, made specifically for an F-type, I would want them to fit perfectly without any modifications.
Old Mar 2, 2023 | 07:43 AM
  #85
Craaaazzy's Avatar
I've already got wheels but my thoughts. 16mm is almost the max w/ stock tires. if one choses to upsize to the 265 fronts/ 305 rears from the svr, then it may encounter rubbing issues. I like the idea of providing a small spacer w/ the wheels so it gives the buyer an option. 5 or 6mm I believe is the max you can go with the stock studs.
Old Mar 2, 2023 | 11:26 AM
  #86
Sponsor
Originally Posted by TheDrainPlug
Hi Stuart,
For sure... we will be tinkering around with some stuff and hopefully can show some examples.
Here's one that's +3mm in the front and +21 in the rear (so a LOT of stagger) and is lowered.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Mar 3, 2023 | 01:40 PM
  #87
jcb-memphis's Avatar
That is "too much" wheel to my eyes...I like sidewall as the real world has ruts, etc. I'd be interested in 20" wheels focused on durability then on ease of cleaning...so a classic design like this works. 265/305 compatibility is a must...with no poke at those tires sizes.... Also needs to accept the OEM center cap....
Thanks for making so much cool stuff. I am really waiting for the rotors....
Old Mar 3, 2023 | 02:05 PM
  #88
eeeeek's Avatar
OEM center cap is downright tiny. On my old F-Type, I had center cap metal badges made for about $20 that I put over the aftermarket wheel center caps.
Old Mar 3, 2023 | 02:12 PM
  #89
Sponsor
Yeah I agree. That photo above isn't our target, just looking at what has/can be done and what's going to be a nice, more aggressive but sensible fitment for most people. 99% it will be 20x9.5 front and 20x11 rear, just add 1/2" and probably 10-15mm additional offset. That would allow 265/305 nicely.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Mar 7, 2023 | 05:53 PM
  #90
Loving the fitment!! Can't wait to see this come to fruition!
Old Mar 8, 2023 | 12:32 AM
  #91
Cgo's Avatar
Cgo
Interested and watching!! There's only one wheel I've seen that looks right on the F Type lowered and stock. The company stopped making them unfortunately. I'm interested in finding another I like especially in gloss black, 20 inch.
Old Mar 8, 2023 | 12:34 AM
  #92
Cgo's Avatar
Cgo
I love this actually minus the gold. But I don't plan on lowering my car, so 21s+ wouldn't look right for me.
Old Mar 13, 2023 | 07:45 PM
  #93
Sponsor
Doing some messing around today. This is set at +12mm front, +15mm rear, on OEM 20" wheels with 265/35/20 front, 305/30/20 rear Cup 2's. Couple considerations. On a 1/2" wider rim that sidewall will be a little less chunky and more stretch. But I don't think you'd want to go much more aggressive than this. This is with a moderate drop.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Mar 13, 2023 | 07:50 PM
  #94
ToysARs's Avatar
This is perfect stance, Stuart. I assume those wheels are 10.5 wheels at the back? With 11" width rims would +15mm give the same exact stance?
Old Mar 13, 2023 | 09:20 PM
  #95
Sponsor
Those are 20x9 ET55 Front, 20x10.5 ET38 Rear. The spacers are fitted at +12mm front +15mm rear. Assuming that we picked what this fitment represents visually, in external clearance the fitment would be :
- 20x9.5 ET49 Front (internal clearance same as OEM, external clearance 12mm less)
- 20x11 ET29 Rear (internal clearance +3 mm, external clearance 15mm less.)
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Mar 14, 2023 | 09:52 AM
  #96
ToysARs's Avatar
Got it, basically, with the 20x11 wheel the outside stance stance would remain the same as above rear wheel pic with the rim extending towards the inside the car to allow for a wider tire.
Old Mar 19, 2023 | 12:50 PM
  #97
Bierry's Avatar
I'm running 12mm spacers w/ Gyrodynes on the R while shopping permanent replacements, so very much looking forward to this. Regarding wheel offset, believe the final wheel and tire assembly position on the car depends on the section width of the tire used.
When the tire section width will still be wider than the new rim eg, 255/35/20 PS4 has 10.2" section width; rim range 8.5-10", the 9.5" rim won't stretch the sidewalls. The 255, on a 9.5" wheel even if ET55, would sit in the same position as using stock 9" ET55 wheels - the 9.5" rim's lips would've moved 'out' 6mm or .25" relative to each side of the tire, but the tire and sidewalls on the final assembly would not relative to the car.
So for fronts I think you'd have
- 20x9.5 ET55 on 255/35/20 PS4 (section width 10.2") with the final sidewalls positions moved 0mm, or
- 20x9.5 ET43 on 255/35/20 PS4 (section width 10.2") with the final outer sidewall position moved out 12mm, or
- 20x9.5 ET49 on 265/35/20 PS4 (section width 10.7"; 6.35mm wider on each side) with the final outer sidewall position moved out 12.35mm, or
- 20x9.5 ET52 on 275/35/20 PS4 (section width 10.9"; another 2.54mm wider on each side) with the final outer sidewall position moved out 11.89mm, and inner sidewall 5.89mm closer to suspension
For rears
- 20x11 ET38 on 295/30/20 PS4 (section width 11.9") with the final sidewalls positions moved 0mm, or
- 20x11 ET23 on 295/30/20 PS4 (section width 11.9") with the final outer sidewall position moved out 15mm, or
- 20x11 ET28 on 305/30/20 PS4 (section width 12.3"; 5.08mm wider on each side) with the final outer sidewall position moved out 15.08mm
Old Oct 14, 2024 | 09:45 AM
  #98
J444G's Avatar
How this turned up? I would like VS-5RS in F-Type sizes...
polarisnavyxj
Sep 4, 2021 05:12 PM
HarryFType
Feb 27, 2020 09:18 AM
Tel
Aug 12, 2016 10:57 AM
jmfan
Sep 6, 2014 04:44 PM
jag_guy_2020
Jul 13, 2014 09:20 PM
