After 10 days and 1000 miles...
Old Jun 18, 2013 | 09:51 AM
thunderF's Avatar
Default After 10 days and 1000 miles...
Managed to squeeze 1000 miles of day-to-day driving into my V8S, and overall, am very pleased.
The engine is quite strong.
Ride and handling very fluid.
Transmission is great in auto mode, especially in dynamic/sport mode. (Holds 3rd or 4th gear in all situations except highway cruising).
Looks great.
Feels good (special) to drive.
Two Complaints:
1)It is objectionably loud. This is a major deterrent to driving the car at anything more than a very sedate pace in civilization, because it causes way too much disruption to other cars, or houses near the car. By virtue of the low frequencies on the sound, it carries a very long way. I will be looking for an aftermarket exhaust to make it quieter!! (Never thought I would say such a thing!!).
2) In manual shift mode, in dynamic/sport setting, if you floor the accelerator (past the kick-down detent) the paddle up-shift does not work, and the car does NOT shift. It also does not shift automatically when it hits the RPM limiter, so the car is stuck in gear and bumping the RPM limiter. (Paddles work fine so long as the accelerator is not depressed past the kick-down detent). Seems like a software mistake on the part of Jaguar. I can’t think of a single reason why this should be programmed this way. (Note that mine is the second V8 I have driven, and both had the same problem.)
Old Jun 19, 2013 | 03:13 PM
Executive's Avatar
Sounds like you are loving the car!
Regarding the RPM limiter; does it only do it in 1st gear?
My XF does the same, but not always. If the wheels bite the tarmac, then it will shift into next gear smoothly. Otherwise, i have to back off, shift and press down on it again.
I like the color. What is it called? Is the Satellite Silver(i think)?
Old Jun 20, 2013 | 07:58 AM
thunderF's Avatar
It refuses to shift up in any gear if you have depressed the accelerator down past the kick-down detent, and will not shift automatically at the rev- limiter if it is in Dynamic mode.
The color is satellite Grey.
calviroman
Sep 21, 2015 06:04 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
