Air Vent stopped raising.
Old Jan 8, 2015 | 10:56 PM
Foosh's Avatar
What is "temperature sensitivity?" I didn't find any such thing in the climate menu.
Old Jan 9, 2015 | 01:09 AM
Unhingd's Avatar
I'm guessing xfactor is talking about the range within which the temperature is allowed to drift. For example, set the temp at 72, ac goes on until temp drops to 70, turns off and then goes back on once temp rises back to 74. the narrower the range, the more sensitive. you don't want it too sensitive, otherwise system is constantly cycling from ac to heat. I know of no car system that allows you to set the sensitivity (and very few home systems). Fairly common, though for commercial HVAC systems.
Old Jan 9, 2015 | 07:24 AM
Foosh's Avatar
Thanks, would have guessed it was something like that, and couldn't imagine why that would be included as a feature on a car HVAC system--especially on a car that doesn't have a locking fuel door.
Old Jan 9, 2015 | 08:03 AM
Unhingd's Avatar
Old Jan 9, 2015 | 11:18 AM
shift's Avatar
Note: Temp sensitivity feature is only available in North America. They've disabled it in other markets.
Old Jan 9, 2015 | 12:52 PM
Foosh's Avatar
OK, but it isn't on my car.
Old Jan 9, 2015 | 01:29 PM
shift's Avatar
Sorry, was being sarcastic about the fuel lock cap and North America. Not sure if there are different options for the climate system or if it's a 2015 thing only? But it's definitely there in my car.
Old Jan 9, 2015 | 03:41 PM
  #28
mshedden's Avatar
Do you have the dual zone option?
Old Jan 9, 2015 | 03:44 PM
Foosh's Avatar
No, and good thinking--that's probably it. Nonetheless, it seems like a completely useless feature.
Old Jan 9, 2015 | 07:57 PM
  #30
shift's Avatar
Temp sensitivity seems like a good idea. Although in practical I haven't changed the setting in the 6 months I've had the car, so in that sense I guess it has been useless to me.
Old Jan 9, 2015 | 07:58 PM
  #31
XFactoR's Avatar
Could you send a picture of what you're talking about?? This is important in light of the fact that Jaguar tells its dealers that the F-Type climate system can normally range within 5 degrees....its peculiar ... even my dealer thought so.
Old Jan 9, 2015 | 08:00 PM
  #32
shift's Avatar
I'll take a pic tonight...but I've actually never used it (left it on the default medium) so I have no idea if it actually works as intended.
Old Jan 9, 2015 | 10:24 PM
  #33
Foosh's Avatar
I suppose in principle, it does. However, if I'm too hot, I turn the dial down a notch or two, or vice-versa. I maybe burn an extra .25 calories a day on that activity.
Old Sep 18, 2018 | 07:27 PM
  #34
Christopher G. Erckert's Avatar
Default Vent Issue: not coming up all the way
Hey Guys,
First thanks for the help when I was scoping out used f-types.
Now that I have a well cared for 2014 F-type S with about 48k miles, I'm dealing with a central vent issue where it gets stuck on half way up half way, or stuck half way on the way down. This happens a large enough percent of time that I plan to take it to dealer. Anyone have comments on what it costs to fix at a dealer.
The car is a dream otherwise.
All the best,
Christopher
Old Sep 19, 2018 | 09:00 AM
  #35
DJS's Avatar
DJS
That was typical on the 2014. Mine raised fine, but I'd have to push it to go back down. There was a TSB for that, and my dealer fixed it the first time it was in for service. Works perfectly now. No idea what you'd have to pay for that, too bad it wasn't fixed under warranty.
Old Sep 19, 2018 | 10:44 AM
  #36
pbad's Avatar
I encountered this issue as well. Sticking halfway up or down intermittently. Fortunately it was fixed under warranty. Looking at my invoice it looks like they replaced that vent assembly, part # T2R17443PAJ and "reprogrammed the module". List price on that part appears to be about 300 but your dealer may mark it up more. Assuming you got the part from the dealership and had them do it my best guesstimate would be 450-600 dollars. I'm basing that on guessing it's 1-2 hours of labor but I don't have any record of what they'd actually bill out for labor on the replacement. You could save a little sourcing the part yourself I would imagine.
Old Jan 14, 2019 | 02:12 PM
  #37
MarshallL's Avatar
I recently had mine looked at by the dealer. They wanted $450 for the part and 2 hours of labor, so total bill would be about $800. Didn't do the service as I figure I can replace it myself.
Old Jan 14, 2019 | 04:30 PM
  #38
JIMLIGHTA's Avatar
Banned
Since the thread has resurfaced and I had no idea the menu existed either, here is a US photo...
There seems to be no way to turn off the center vent, only to keep it up sts.
Old Jan 20, 2019 | 07:31 PM
  #39
John Jones's Avatar
Banned
Looks like Im going to have to replace mine too. Any part #s and prices will help. This is usually an unhingd thing
Old Jan 21, 2019 | 09:41 AM
  #40
MarshallL's Avatar
Default Replacement Part
This is the cheapest I have been able to find the replacement part $307 plus shipping
https://parts.harperjaguar.com/oem-p...ver-t2r1450pvj
