AJ126 teardown
Old Sep 24, 2023 | 03:43 PM
jcb-memphis's Avatar
Originally Posted by sov211
But rod bearing wear can be affected by infrequent oil changes, wrong oil specification and so on.
And yes the rear coolant pipe is now available in metal for the 3.0 engine, but not yet for the 5.0.
Originally Posted by cujet
The rod bearing wear is concerning. As that is not directly affected by coolant overheating. Although, a severe overheat can also overheat the oil.
I do not use 0W-20 in my AJ126.
Metal rear coolant manifold? Anybody have a link?
I have all the cooling stuff in mettal, front pipes, rear cross over, the little stuff/elbow, etc.
On oil weight - be mindful that if you go "thicker" you could outsmart yourself on this and actually make things far worse.....I don't know the clearance spec on our engines but the following chart shoudl raise some alarms if it quite tight and you use say 5w-40.
and here is another:
Here is the AJ133 spec (AJ126 is my assumption):
https://www.engineprofessional.com/a...Q414_42-48.pdf
The main bearings are numbered 1 to 5 starting from the front of the engine. There are five grades of standard main bearings available, each being color coded. Journal sizes are marked on the rear of the crankshaft to assist one in select bearing fit to provide desired minimal oil clearance of not less than .00087” (.022 mm) or greater than .0016” (.040 mm).
GeorgeIII
Oct 23, 2022 11:01 AM
lspab
May 3, 2019 04:03 PM
LstFord
Jul 18, 2014 07:26 PM
keestanis
Dec 25, 2013 10:04 AM
