Any Tips on Replacing High Pressure Fuel Pump(s)?
Old Oct 15, 2021 | 06:30 AM
benfbrown's Avatar
Default Any Tips on Replacing High Pressure Fuel Pump(s)?
Hello all,
My 2014 F-Type Base has a noisy rear high pressure fuel pump that I need to replace. I didn't see any DIY posts on this but I do have the service manual and have reviewed the procedure. It seems a bit complicated so I am wondering of someone who has done this job has any "lesson's learned" or tips that they would like to share.
Thanks in advance!
Old Oct 15, 2021 | 09:08 AM
clubairth1's Avatar
Community Influencer
I thought the 2 hi pressure fuel pumps were mounted on the engine as they are gear driven off the engine? The rear pump is just a low pressure supply pump that is electrically operated?
Old Oct 15, 2021 | 10:35 AM
benfbrown's Avatar
Correct...I am referring to the rear one of the two with the #1 high pressure fuel pump in the front position and the #2 in the rear position. I could have just said the #2 pump : )
Bearmkt
Jan 4, 2023 09:16 PM
lslincoln
Jun 15, 2022 06:37 PM
Obi
Sep 8, 2021 03:19 PM
adenshillito
Mar 28, 2016 10:13 AM
