Any way to make it quieter?
Old Jun 3, 2020 | 11:59 AM
Glovebox's Avatar
Default Any way to make it quieter?
I know I know, this will be a heresy, but I'm thinking about getting an F-Type V8, and I'm wondering if anyone has any suggestions on aftermarket exhausts that will tone herdown a bit.
Aaand let the thrashing begin.
Old Jun 3, 2020 | 12:02 PM
eeeeek's Avatar
In the standard mode, they are rather quiet if you keep from putting your foot to the floor, except at startup.
Old Jun 3, 2020 | 02:15 PM
Eubster's Avatar
Agreed. I just got my 2017 R on Monday and driving in standard mode is pretty reasonably quiet actually. Switch to dynamic mode and the exhaust baffles open up giving you noticeably more sound and a few burbles and pops. Kick the shifter over to S to unleash your inner hooligan with crackles and pops for days.
Old Jun 3, 2020 | 03:11 PM
mrjohnt's Avatar
You could sell it?
Old Jun 3, 2020 | 03:33 PM
dsprague27's Avatar
Old Jun 3, 2020 | 05:51 PM
scm's Avatar
scm
The F-Type is a bit schizophrenic - ranges from ***** cat to roaring beast. Your right foot's choice as to its behaviour.
Old Jun 3, 2020 | 06:03 PM
Ltrain925's Avatar
its quiet as can be with the baffles closed, I don't think there is any way to make it quiet in dynamic mode.
Old Jun 5, 2020 | 04:53 PM
lizzardo's Avatar
Under what conditions do you want it quieter? Also, is it louder than you'd like for you, or for those outside?
I hate the sound the symposer pumps into the cabin, but that's trivial to fix.
Old Jun 5, 2020 | 05:48 PM
Finman's Avatar
I hated the symposer too lizzardo. It's a 10 minute fix max. The cabin sounds much better. But I'm 65 years old so I understand it's not for everyone.
Old Jun 5, 2020 | 05:54 PM
lizzardo's Avatar
Disabling, I'd put it at two minutes, maybe three the first time. Removing all that crap though ... I'd like it gone but it'd be a real pain and not worth it unless I had the engine already out.
I'm not 65, but not young. What I didn't like is the sudden switch to disembodied noise in the cabin. Engine noises should come from the front, exhaust noises from the back. Now, that's what I get.
Old Jun 5, 2020 | 06:36 PM
OzXFR's Avatar
I find this discussion about the symposer interesting.
I disabled/blocked mine a couple of years ago and I really couldn't tell any difference, it sounded exactly the same to me.
So I re-enabled/unblocked it and again zero difference.
All I can hear under the conditions where it is supposed to work (medium to heavy engine load and and plenty of right hoof) are the exhaust and the SC whine.
Maybe they are drowning out the symposer, maybe it never worked anyway, I dunno!
Old Jun 5, 2020 | 09:13 PM
eeeeek's Avatar
On mine, I can just hit the exhaust button while it's in dynamic mode and it goes quiet.
Old Jun 5, 2020 | 09:15 PM
eeeeek's Avatar
What, what? We have a symposer?
Old Jun 5, 2020 | 09:46 PM
OzXFR's Avatar
Yep.
On both the V8 and V6.
Here's the relevant page from the AJ133 Technical Training doc (it's about the V8 but the V6 has the exact same gizmo):
Old Jun 6, 2020 | 09:34 AM
lizzardo's Avatar
Originally Posted by OzXFR
Yep.
Here's the relevant page on disabling it:
https://www.jaguarforums.com/forum/f...5/#post1553181
I have no explanation for your experience other than that it wasn't working to begin with. It's a night and day difference for me. A typical place I'd get it was a freeway merge on my commute. It's been some time but I think it was probably 4th gear (on the 6MT), maybe 3000rpm, half throttle. It'd accelerate moderately, as expected, then reach maybe 3500rpm and the sound would just switch on. When I first got the car I thought it was the exhaust valves opening, but after time I was able to distinguish the difference.
Old Jun 11, 2020 | 12:49 PM
devmen's Avatar
@lizzardo Do you think plugging/defeating the symposer will address highway drone? I will admit, I have the VAP exhaust but noticed the highway drone with the exhausts closed. Since it's a small job I'm might do a test, I'm just not as handy as everyone here.
Old Jun 11, 2020 | 01:00 PM
lizzardo's Avatar
I doubt it will change that, since the symposer only activates under moderate load and "highway drone" is cruising at light load.
Still, it's really easy and you might just like the sound better when under load. I do with the stock muffler. It might be less pronounced a change with the VAP. I don't know.
eglisau619
Mar 9, 2021 07:08 PM
06360
Feb 26, 2020 08:32 PM
FullChat
Nov 15, 2017 01:12 PM
Stuart@VelocityAP
Oct 31, 2017 08:39 PM
diablomkii
Sep 14, 2015 11:10 AM
