Anyone Dealing With Rattles?
Old Jun 7, 2022 | 08:29 PM
Iticip's Avatar
Default Anyone Dealing With Rattles?
I've got a few rattles going on. I've heard about a speaker rattle, I seem to have that.
Is there a master rattle thread? Or any popular DIY rattle fixes you know about?
Old Jun 7, 2022 | 09:14 PM
Thomarcha's Avatar
The window of my LHD driver’s door rattles when the door is open and the window is automatically lowered a bit.
The dealer tells me it is a window regulator that is currently on back-order.
Old Jun 7, 2022 | 10:22 PM
OzXFR's Avatar
Many rattles can be fixed by applying tape of some sort, eg felt tape, double sided tape, even the old favourite duct tape.
The trick is finding the real source/cause of the rattle as a lot of the time on a car the noise appears to come from a spot that is nowhere near the actual source.
On the F-Type I eliminated the common hatch cover rattle by wrapping the mounting pins/pegs in a few rounds of electrical insulation tape so that the slots in the cover fitted much more snugly over the pegs. That also prevents another common problem with the hatch cover - sliding so far to one side that it falls off the peg on the other side.
That was the only rattle I have had on the F-Type but on other cars including my XFR and XFS I fixed many rattles with felt tape or double sided tape - glovebox lids, centre console cubby lids, hush panels, speaker covers, window cables inside doors and so on.
Old Jun 8, 2022 | 04:38 AM
scm's Avatar
scm
The "proper" fix for that is to apply a "bush grommet" to each side - p/n T2R35506 if you're interested.
Old Jun 8, 2022 | 05:48 AM
supersportmtl's Avatar
HOnestly,
Most cars have rattles today! Unless its a Rolls Royce, you will deal with the occassional rattle. My 2022 Bentley Continental GT has a rattle in the back somewhere... it's frustrating but it has a good sound system lol
Old Jun 8, 2022 | 06:09 AM
OzXFR's Avatar
Yep, my local JLR dealership did that early in the piece and it didn't help. So I ripped them out and applied the electrical tape instead, instant 100% fix and zero problems many years later.
Old Jun 8, 2022 | 12:57 PM
sov211's Avatar
Originally Posted by supersportmtl
HOnestly,
So true. But I can’t have the ONLY F-Type that has zero rattles (even on the very poor pavement of Victoria roads), can I? No rattles, a really excellent sound system, acceleration that is terrifying, crisp handling, panels with uniform and tight gaps, flawless finishing to the interior, a factory paint job that has zero orange peel and which looks like a green mirror….and I have pretty high standards.
Old Jun 8, 2022 | 01:08 PM
scm's Avatar
scm
Yeah, I had a VW that had a rattle, too.
Old Jun 8, 2022 | 01:23 PM
s6crappy's Avatar
I have the same rattle if window is down about an inch it rattles in the door scheduled to be looked at curious to see what my gang says
Old Jun 8, 2022 | 01:49 PM
Cheapo911's Avatar
I have a slight rattle behind my left ear (LHD) that sounds like a mouse squeaking like crazy lol. Still tracking that one down.
Old Jun 8, 2022 | 01:58 PM
jcb-memphis's Avatar
My car has no rattles unless it is super cold out (under 20F) and even then, they are minor...due to all the different materials with different expansion coefficients is my guess.
Panel gaps...it has an eclectic mix there.
Old Jun 13, 2022 | 04:14 PM
Valerie Stabenow's Avatar
Default Somewhere on the right/passenger side
An annoying tick, like a plastic pigtail rubbing/hitting against something. Might be under the seat..when a passenger's there, the sound is lessened. I stuffed some lengths of soft foam strips underneath, but that didn't end it. .. thought it was in the passenger visor/mirror, but that's not it either. I had a friend design a portable noise/sound detection system that has a tiny microphone, he has to fine tune it and hoping to have it useable by the end of June.
Old Jun 17, 2022 | 08:56 PM
Default Update to above thread
Poking around and still trying to find the rattle. Had the hood open and noticed that on the right/passenger side of inside upper there is a round plastic disk, about 4 in in diameter. It's plastic and it was loose. It has two push fasteners so I pressed them and the disk tightened up. Will know on the next drive.
Old Jun 19, 2022 | 05:42 AM
WILDP450R's Avatar
Nope, you are not the only one with rattles. On my long road trip yesterday…about 730 miles one way, I noticed that I had a stereo induced rattle around the passenger seat area when playing the music loud. At our next rest stop I moved the seat forward away from the rear as it was touching it, moved my cane off the seat and collapsed it and moved a few other items off the seat. Voila, no more bass induced rattles. The car exhaust and motor sounds, awesome, the upgraded Meridian stereo with DTS and two subs, also awesome, = pure bliss. My car is also a convertible and at 70-80 mph top up the car was quiet for a sporty ride. I am n idiot geek, so I will address bass anomalies with Dynmaat later on. So far so good with regards to not having any other rattles.
It was actually great trip with no issues. Did I say I love the exhaust and stereo, pure awesomeness.
Old Jun 20, 2022 | 11:36 AM
sov211's Avatar
You misread my note. My car has NO rattles at all! That was my point.
Old Jun 24, 2022 | 09:59 PM
TH3FRB's Avatar
My 2008 VW GTI with 140k miles has significan;ly less rattles than my F-Type. In fact, the VW is pretty damn solid. The F-type is an embarrassment with passengers unless the windows are down.
Old Jun 24, 2022 | 10:25 PM
kb58's Avatar
I have a 2013 F150 truck, and below about 45 degrees, something in the steering wheel drags noisily when turning. Once it warms up, it goes away. Point being, most cars have "issues" of some sort.
Old Jun 25, 2022 | 08:17 AM
Vindi's Avatar
I have no rattles at all, had trunk cover noises initially, fixed that. Had a squeaking rear shock absorber - replaced under warrantee.
Now silent aside from the occasional squeaks from the seat belt rubbing in the seat when the temp/humidity is right for that - a wipe with some leather conditioner fixes that temporarily.
Speakers rattle of course if bass & volume turned up - so I dont do that .
Old Jun 25, 2022 | 03:40 PM
davidmaria1's Avatar
I get a whining noise from the passenger seat whenever I exceed 75 mph or accelerate too quickly. It only happens when the seat is occupied.
Old Jun 26, 2022 | 08:58 AM
Borbor's Avatar
Bass speaker rattle from the back is just poor JLR design. The speaker grills actually press against the rear ( pretend )subwoofer rolls and their mounting bracket so any louder bass will cause that annoying vibration sound . Could just have easily been designed to have a 1cm gap instead . Dynomatting the back or the grill and carpet surround doesn’t get rid of this. Other than leaving out the speaker grill from the carpet you are left with trying to create more of a gap with foam spacers appropriately place(hard to do well) or disconnecting the rear subs(no big loss) or not turning up your music. If you have a aftermarket subwoofer definitely disconnect the OEM subs. Can just remove some of the pins from the speaker connector so easily reversible. Dynomatting the doors is a no brainer ,very necessary if any rattles from there and still worth doing even if no rattles as tightens up the bass a lot . Dynomatting the rear not worth doing for rear speaker rattles as doesn’t address the cause.
