Anyone Dealing With Rattles?
Old Jul 25, 2022 | 09:39 AM
aph202's Avatar
Hi - brand new here, also on a quest to solving rattles!
I am not very hands-on with maintaining cars. Does anyone UK based have any recommendations for garages that have fixed F Type rattles?
I bought a 2014 F Type V6S coupe about six months ago, love the thing, but goodness is the build quality shoddy in some parts. I have stereo rattles and brand new today, a very irritating trim rattle just behind my right ear.
I waited out to get one with Meridien, but of course when I turn the volume up it rattles like mad behind the seats. The dealer I bought it from has had at least four attempts at sorting this and on the last attempt announced "it must have been like that from the factory". I dread to think what they've done behind the bulkhead carpet.
On this forum I found the technical bulletin JLR released to "resolve" this, which was JTB00432v2 - I am told that as this wasn't done near the time of the release, it is now too late to have done for free; so I am not stuck within the network. A stereo specialist in Reading want about a £grand to dynomat the hell out of the whole car, but I am worried that will dullen the exhaust noise and also I read here won't solve the sub vibration issues anyway.
So my quest is for a skilled mechanic who is an expert in identifying and resolving rattles and also interior trim fitting so that the solution lasts and looks decent. Does anyone have any recommendations?
Many thanks,
Adrian.
Old Jul 26, 2022 | 06:24 AM
Carbuff2's Avatar
There are videos of the operations needed to resolve the sound system rattles on YouTube.
I'd suggest asking an auto sound business.
Old Jul 26, 2022 | 06:05 PM
OlyFtype's Avatar
My '22 P450 has a really annoying "Tap, Tap" noise that seems to be coming from behind the driver's area of the cabin (left rear). Almost sounds like something is swinging slightly when the car just begins to move fwd and the chassis or body flexes a bit... very intermittent and is barely discernable or very noticeable. With only 4600 miles on the clock, suffice to say that I'm a bit put off given the supposed caliber of this car. And salt in the wound... none of the dealers that are close to me can schedule an appointment until either October or November -- citing "lack of staff" as the rationale for unavailability of appointment times. I have found a dealer across the border (about 2-hour drive) that offered a late August appointment... so snatched that up. Will just need to figure out logistics of what to do while the dealership has the car for at least 2 days. Lucky I just retired... so time I have.... but this is frustrating, nonetheless.
Old Jul 28, 2022 | 04:59 AM
Borbor's Avatar
One for the dealer obviously given your car is new. Could really be anything. There is a rear quarter window drain that can flop around and give that noise if it hasn’t been attached and routed properly. You have to take out the rear carpeted area to see this area.
Old Aug 10, 2022 | 12:44 PM
tepid's Avatar
Originally Posted by Iticip
I've got a few rattles going on. I've heard about a speaker rattle, I seem to have that.
Is there a master rattle thread? Or any popular DIY rattle fixes you know about?
Mate, I've had this going on ever since I got mine back in April. Drives me nuts. Waiting for the true thread to come through, haha.
Old Aug 10, 2022 | 06:13 PM
Borbor's Avatar
Speaker rattle from the front ie:door is easy and always fixed by Dynamatting the door cards. See any of the stereo upgrade threads and will also tighten the bass immensely so worth doing even for those without a rattle.
The rear speaker rattle is almost impossible to fix if you want to retain the rear subwoofers behind the seats. Disconnect them will solve the rattle and they hardly do / add anything to the sound overall so could be considered. I am exploring replacing them with bass shakers with good results so far as better than the oem subs in my opinion.
Unfortunately jag designers have dropped the ball on this aspect and actually have the rear speaker baffle actually pressed against the subwoofer/subwoofer frame instead of having it 1cm proud and not touching. Any vibration from those subs will rattle against the plastic cover for those that have this problem. There is a foam gasket between the two that is compressed between them. Maybe replacing this with a denser foam roll may help but have not tried this myself. Dynamatting this area does not address the problems and so doesn’t help. I think those without this problem still have compliant foam whereas those with the problem the foam has compressed and doesn’t re-expand any more and so no damping occurs allowing the grill to vibrate.
Old Aug 15, 2022 | 08:36 AM
tepid's Avatar
So I took it upon myself to investigate and tackle the problem head-on over the weekend. What I found was that a significant part of the door subwoofer had detached from the rear of the speaker housing bracket, which was causing the rattling sound.
I unfortunately did not take any photos, but it was a simple and quick fix with nothing more than a Torx 20 and 30 bit, some Gorilla Glue, and time. I left it to cure for about 30 minutes before reinstalling the sub and did not fully test it until 24 hours later by slowly turning the volume up and down. I also tested the different levels in tones along with the manufacturer surround sound presets.
I'm content to say that it now works great with the sound being back to what it should be! Not to mention I probably saved a ton in costs.
Old Aug 15, 2022 | 09:00 AM
  #28
Sultan1966's Avatar
Drove me crazy but finally found an annoying rattle in mine. The left plastic sunvisor screw/bolt cover on the drivers side. All others are fine. Guess wear is due to putting visor up and down. Now to figure out how to remove/tighten without breaking the plastic cover.
Old Aug 18, 2022 | 08:34 AM
tepid's Avatar
Forgot to mention that I also used plastic pry bars/panel poppers that I picked up from AutoZone which worked fantastic for getting in between those push pins.
Old Sep 3, 2022 | 06:45 PM
  #30
OlyFtype's Avatar
Default "CREAK" Resolved
Huzzah! 2 days at the dealership and they found that the "creak" I was hearing was coming from the drivers side rear tail light assembly being over-torqued. They reset to factory spec and the friction between the assembly and body panel stopped. Great job of troubleshooting by the technician at JLR of Portland, OR!!
Old Jul 1, 2025 | 06:22 AM
  #31
Lothar52's Avatar
Originally Posted by sov211
So true. But I can’t have the ONLY F-Type that has zero rattles (even on the very poor pavement of Victoria roads), can I? No rattles, a really excellent sound system, acceleration that is terrifying, crisp handling, panels with uniform and tight gaps, flawless finishing to the interior, a factory paint job that has zero orange peel and which looks like a green mirror….and I have pretty high standards.
Your it!! The only one! I have developed a rattle coming from the below the center vent to the cup holder. It’s a loud metallic rattle worse at above 2000 rpm. It’s related to engine vibration I guess….. if I’m going 70mph in 8th it will constantly rattle and then I kick it into 7th manually and goes completely away. Drives me nuts I can’t enjoy the engine noise because of it need to have radio on - it’s that bad. Does feel like it’s inside the cabin to the right of my thigh nothing I touch or hold stops it
Old Jul 1, 2025 | 09:45 AM
  #32
Valerie Stabenow's Avatar
Default You may want to investigate this....
Had a right side rattle that I thought was in the door... NOT... something in the glove compartment...No... the ventilation riser... NO.... Then I came upon this thread/post and for ZERO money and aggravation, solved it!
https://www.jaguarforums.com/forum/f...solved-219522/
It's been over 2 years, and it has not returned. I also think having a passenger in that right seat upsets the geometry on that side of the car.. as I would hear it more noticeably when someone was sitting there.
Old Jul 1, 2025 | 10:28 AM
  #33
cpq100's Avatar
I just checked mine. One of those bolts was loose on mine as well. I can't say I ever heard a rattle, but the hood on the side that was loose would on occasion not close.
Old Oct 30, 2025 | 08:51 AM
  #34
Bobby V's Avatar
Default Had the same thing
Originally Posted by Cheapo911
I have a slight rattle behind my left ear (LHD) that sounds like a mouse squeaking like crazy lol. Still tracking that one down.
Had the same thing on my 2013 V8S convertible turn's out it was the passenger seat all the way back on the runner's and rubbing on the back bulkhead
Old Oct 30, 2025 | 09:22 AM
  #35
TH3FRB's Avatar
If it's definitely more of a squeeze than rattle, it could be the seat touching the rubber stopper or the wing of te seat touching the rear trim panel. Sit in your seat parked abd wiggle around a bit.
Old Oct 30, 2025 | 04:28 PM
  #36
DMeister's Avatar
I’ve only gone through 2 summer driving seasons with my 2024 R, but it’s been tight as a drum far. No rattles.
WaterDragon
Jul 2, 2021 06:01 PM
Supercharged81
Aug 19, 2019 06:10 AM
jm717
Feb 27, 2016 09:31 AM
ukdude
Mar 7, 2015 07:38 AM
