Audio settings question
Old Dec 16, 2020 | 11:17 PM
19FRG's Avatar
Default Audio settings question
I must admit I am no audiophile, I was curious what settings you Gents have your stereos set on such as surround, balance, treb,bass etc. I have the 770w surround setup. I typically listen to harder Rock and country, and blues. Thanks 😁
Old Dec 16, 2020 | 11:35 PM
bjg625's Avatar
There are some early disscusions on this. I tried one that really worked. maybe someone can refer you to them
Old Dec 17, 2020 | 03:50 AM
Robtrt8's Avatar
I'm an old school two channel guy (home system is Linn), musical taste is all over the place, Doobie Brothers to Dua Lipa. Tool to... ( not Toto, yuck).
I started with the system flat and tried all the surround tunes but none of them had a good sound stage, and while the system is somewhat detailed, the highs sounded a bit shrill.
And the sub is a muddy mess.
I find the best way to accentuate the mid bass (which is where you get the punch in the chest dynamics) is to turn down everything else a bit.
I have the surround turned off, fader set all the way forward, treble down two clicks, bass left flat, sub down four clicks.
Old Dec 17, 2020 | 07:04 AM
2004XJ8's Avatar
I found on my 2014 convertible that with the roof up the sound level is different (lower)then when the roof is down. I think the system is designed this way to keep the sound level down in such a small space.
I found with the roof down the sound dynamics and sound spectrum is fuller. Roof up the eq is much flatter across the spectrum.
Old Dec 17, 2020 | 05:28 PM
19FRG's Avatar
Thanks @robert, just what I was looking for. Ill play around with that.
Mad Scientist
Mar 25, 2024 08:05 AM
Byrnout
Mar 25, 2020 12:41 PM
NavyBlue
Jun 22, 2018 06:12 PM
drbill
Feb 5, 2017 12:11 AM
maxthrottle
Aug 29, 2013 01:47 AM
