Auto Lights / Rain Sensor not working
Old Jun 26, 2024 | 11:49 AM
reppe711's Avatar
Question Auto Lights / Rain Sensor not working
Hey guys,
I really hope any of you has an idea for my issue.
Got a 2014 F-Type convertible - Automatic Lights are not working. They always turn on, when I switch to "Auto Mode". Also SDD is showing the Error "Windshield Misting Sensor".
So I replaced the Sensor with a used one, but the issue is still there.
Also replaced fuse F21 - "Rear Camera, Headlamps, PDC, Interior Mirror". This was the nearest I could find.
I couldn't find any procedure in SDD.
Should I update the BCM? Or does anyone know which module is controlling the sensor?
...The former owner disconnected the battery for 6 months, so it's possible that some modules lost their config. Needed to relearn the KVM and the cluster to fix an issue with the keyless system.
Thanks a lot guys and best regards from Germany,
Tim
Old Jul 2, 2024 | 06:00 AM
reppe711's Avatar
Hey guys,
Next things I tried:
- Reset the DTCs, just to be sure
- "Configure Existing Module - BCM" --> There were some SW Updates
...Unfortunately, both didn't help. The error is still there.
Do you have any more ideas? I assumed the rain/light Sensor is connected and controlled by the BCM - right?
Thanks a lot for any idea,
Tim
Old Oct 6, 2024 | 02:48 PM
reppe711's Avatar
Well, too easy.
Checked the wiring diagram and found it's fuse F31 - which was apparently blown.
Replaced it and tada - it works again...
walkman1
Aug 16, 2017 07:24 AM
phd12volt
May 28, 2011 06:39 PM
Jag Breeder
Apr 16, 2011 01:40 PM
turbo68
Sep 15, 2010 09:17 PM
justinb67
Jan 1, 2009 10:40 AM
