Auto Stop Start stoped working?
Old Feb 3, 2025 | 02:31 PM
GAT1174's Avatar
Default Auto Stop Start Stopped Working?
I know most people hate this feature but I prefer it on.
The feature recently stopped working does anyone have a suggestion for troubleshooting?
I’ve already tried using the button to turn it off and then back on again.
If I were stopped at a light and it hadn’t activated I could usually get it to activate by stepping harder on the brake.
The engine used to turn off if the feature was activated and I removed the seat belt but it no longer does that either.
Thanks.
Old Feb 3, 2025 | 02:35 PM
User 42324's Avatar
Isn't this feature turning off associated with a low battery ?
Old Feb 3, 2025 | 02:38 PM
Tomkatb's Avatar
Replacing the main control board fixed mine. $2000
I took the F in because I had a warning light as well on the dash that said there was a parking brake issue.
Old Feb 3, 2025 | 02:47 PM
Tomkatb's Avatar
Often a new battery fixes it.
Old Feb 3, 2025 | 02:58 PM
DJS's Avatar
DJS
What year is your car? Early cars (like mine) had a 2nd battery. I removed my 2nd battery when it failed.
Also, as mentioned, a low or failing primary battery will disable start/stop. I had this happen in my XE.
Old Feb 4, 2025 | 07:35 AM
SportsEngineer's Avatar
I have a 2015 R, and mine was also not working. Mine has a second smaller auxiliary battery in the trunk of the car, on the opposite side of the primary battery.
I replaced the auxiliary battery, and the start/stop started working again. Useful when stuck in stop and go traffic.
Old Feb 4, 2025 | 08:33 AM
WSHudds's Avatar
Consider it a blessing. Auto stop is a silent engine killer. It puts so much stress on the engine, oil pump and the constant oil pressure drop could cause bore scoring among other issues.
Switching it off is part of my get ready to take off process 😊
Old Feb 4, 2025 | 01:54 PM
Valerie Stabenow's Avatar
Default +1 on turning off S/S
I understand the S/S is to improve gas mileage rating, but I do not see anything good coming out of repeated offs/ons to starters, oil levels, etc. already described above.
With my 6 speed, it's Power On, let the car settle down to idle, Dynamic On, Active Exhaust on, S/S OFF. Go have fun!
Old Feb 4, 2025 | 01:56 PM
When I turn on Dynamic, s/s automatically goes off.
I have model year 2015. Is it different than other model years?
(It’s raining now where I am, so I have rain mode on. Same thing: s/s automatically disabled with rain mode on.)
Old Feb 4, 2025 | 02:01 PM
Carbuff2's Avatar
Having the engine OFF in stop-n-go situations reduces pollution too, a factor in European standards..
Supposedly there are designed-in mitigations to the automatic transmission hydraulics, and engine oil pump.
In theory, these things are important, but in practice...probably not so much.
Old Feb 4, 2025 | 02:04 PM
eeeeek's Avatar
Yes. The first couple of years had a secondary battery that was dedicated to the Stop/Start.
Old Feb 4, 2025 | 02:06 PM
eeeeek's Avatar
Thanks.
As others have stated, it is really necessary information to include your model year and country, as there are differences between model years and regions. If you have a 2015 US model, for example, you have a second battery just for the stop start. If it is a 2015 UK model, or a 2016 US model then you don't.
Old Feb 4, 2025 | 02:09 PM
lizzardo's Avatar
If the battery is not sufficiently charged, start/stop will be disabled. I think the fears about it are overblown, I usually have mine disabled. I don't want it to stop the car if I know it will only be for 5-10 seconds. I will enable it when I feel it will be helpful, e.g. long stoplights, but I avoid routes like that when possible.
I did notice it stopped working a few years ago. I had the dealer check it because I was under warranty and they replaced the battery. That fixed it.
Old Feb 4, 2025 | 02:52 PM
DJS's Avatar
DJS
For those interested, this document has detailed start/stop info…
https://www.dropbox.com/scl/fi/fturj...=ns81kk9u&dl=0
Before the engine is stopped the following parameters must be detected:
The vehicle must be stopped from a speed greater than 4 km/h (2.5 mph)
Sufficient brake pressure must be applied to the brake pedal to ensure the vehicle is stationary
OR
The vehicle must be stationary and 'P' or 'N' selected on the TCS.
Before the engine is restarted, the following parameters must be detected:
The accelerator pedal is pressed (ECM detects a signal from the APP (Accelerator Pedal Position) sensor)
The vehicle speed exceeds approximately 1 km/h (0.5 mph)
Climate control system demand increases (signal from the ATCM (Automatic Temperature Control Module))
Brake vacuum has been reduced from repeated use of brake pedal with engine not running (detected by ECM
from the brake vacuum sensor)
Battery charge becomes low
Auto stop/start is deactivated using the Auto stop/start switch in the floor console
A steering wheel paddle switch is operated to select a gear
'D' (Drive) or 'S' (Sport) selected on the TCS and the brake pedal is released
'R' (Reverse) is selected on the TCS.
The following conditions will prevent an Auto stop:
The external ambient temperature is less than 0°C (32°F) (detected by the ECM via the AAT (Ambient Air
Temperature) sensor)
The external ambient temperature is more than 40°C (104°F) (detected by the ECM via the AAT sensor)
The engine has not reached its optimum operating temperature (detected by the ECM via the ECT (Engine
Coolant Temperature) sensor)
The driver door is opened (detected by the CJB from the door ajar switch)
The driver safety belt is not fastened (detected by the RCM (Restraints Control Module) from the driver seatbelt
buckle switch)
The climate control system requires the engine to be running, for example; windshield demist selected
The battery charge is low (signal from the GWM)
The hood is open (detected by the CJB from the hood ajar switch)
A steering wheel paddle switch has been used to select a gear.
Old Feb 5, 2025 | 06:28 AM
DMeister's Avatar
If only this feature would break, I’d be a happy man. Then I wouldn’t have to remember to disable it or look into disabling it somehow…On my list of things to do at some point. I cannot stand that feature.
Old Feb 5, 2025 | 10:12 AM
Thunder Dump's Avatar
If you have a convertible, smartTOP can take care of this for you.
Old Feb 5, 2025 | 10:16 AM
DMeister's Avatar
Ah yeah, okay, I think I vaguely remember reading this…Probably one of your posts ;-0
I have a coupe. Does that mean there is no clean solution like pulling a fuse or something? I kind of assumed to this point that it might be something simple like that, but I’m getting the impression that this is not the case based in your comment.
Old Feb 5, 2025 | 10:49 AM
DJS's Avatar
DJS
There’s a connector in the trunk you can unplug, it’s been posted here quite a few times. I’ll see if I can find it…
Edit: here it is…
https://www.jaguarforums.com/forum/f...attery-146010/
Old Feb 5, 2025 | 12:01 PM
DMeister's Avatar
Edit: here it is…
Okay, I assume that works the same way on facelifted cars? The last post there was from 2017. Regardless, thanks for taking the time to post that.
Old Feb 5, 2025 | 01:25 PM
Erniewhoo's Avatar
[QUOTE=GAT1174;2821555]I know most people hate this feature but I prefer it on.
Thanks.[/QUOTE
most likely it's a separate battery
That it is used to power that option
