Auto Stop Start stoped working?
Old Feb 5, 2025 | 01:50 PM
DJS's Avatar
DJS
Originally Posted by DMeister
Okay, I assume that works the same way on facelifted cars? The last post there was from 2017. Regardless, thanks for taking the time to post that.
I assume so. That module is the VQM (Voltage Quality Module), and it replaced the battery that early cars have.
Old Feb 6, 2025 | 11:38 AM
Gearhead01's Avatar
OP stated in a different post that he has a 2017 F Type. That means just a single battery. I had a similar situation with my 2016 when the battery started to get old. Replacing the battery fixed the issue. Shortly thereafter, I disconnected the wire in the trunk/boot to deactivate the system so it won't be a problem anymore 🙂.
Old Feb 6, 2025 | 01:54 PM
Pupilbone's Avatar
Originally Posted by Thunder Dump
If you have a convertible, smartTOP can take care of this for you.
I’ll have this installed as soon as I remove her winter pj’s in April/May. Really looking forward to the features it provides.
Old Feb 14, 2025 | 02:03 AM
takeapieandrun's Avatar
Mine worked for a single day when I got my Powertex Lifep04 battery. I'm assuming the BMS is not charging it up fully as it needs to be reset. Still haven't gotten around to doing that.
Old Feb 15, 2025 | 01:38 PM
OldGuy1's Avatar
I have an Antigravity battery in my XE and had the BMS reset. The start top continues to work. Hopefully when you reset yours, all will be normal.
Old Feb 18, 2025 | 12:42 PM
OldGuy1's Avatar
takeapieandrun did you get this figured out? Yesterday I started getting Charging system faults so hoping you got it fixed....
Old Feb 23, 2025 | 12:45 PM
68MBC's Avatar
I've replaced the second/smaller battery when mine did the same thing. Now S/S works, just need to remember to switch it off every time :-)
The second battery or the capacitor based device on newer models is there to protect car critical electronics from powering down on engine start if battery voltage drops, so I've chosen to replace that smaller battery anyway when it failed.
Old Feb 24, 2025 | 07:30 AM
  #28
SassySarah's Avatar
The start/stop feature on my Alfa Stelvio stopped working some weeks or months ago (which was fine with me) until I replaced the battery last week. It's working now and I theorize that's because the original battery was not holding a sufficient charge.
Panelhead
Feb 14, 2024 10:05 PM
peter1
XE ( X760 )
Mar 24, 2018 01:45 PM
Magnumforc
XF (X260)
Oct 23, 2016 03:14 PM
shift
May 11, 2015 10:46 PM
rpontual
Oct 5, 2014 06:15 AM
