base model or s
Old Jul 16, 2015 | 10:12 AM
  #41
buickfunnycar.com's Avatar
Originally Posted by ghatter
I'm just jumping in here to say that yes, you do get dual zone HVAC on the base model...
My '15 base car does not have dual zone HVAC...drivers side is the same as the passenger.
Old Jul 16, 2015 | 10:19 AM
  #42
mshedden's Avatar
Yes, its an option (part of the premium/vision pack), but not standard.
Old Jul 16, 2015 | 10:32 AM
  #43
Foosh's Avatar
Correct, and my base car does not have it. I've had it on many cars and found it to be essentially worthless. That's particularly the case in the F-Type's miniscule cabin.
Old Jul 16, 2015 | 10:33 AM
  #44
ghatter's Avatar
Hmm... ok, now I'm going to have to check mine when I get home because I have a '15 base model, with no options, and really thought that I had dual zone HVAC. I know there are two knobs, and each displays the temperature, but I hardly ever touch it and probably haven't tried to set them to different settings.
Old Jul 16, 2015 | 10:48 AM
  #45
Foosh's Avatar
Yes, there are two knobs, but regardless of which one you turn it will change the indicator to the same temp on the other.
Old Jul 16, 2015 | 11:15 AM
  #46
ghatter's Avatar
Oops... well I guess the fact that I've never even tried it and assumed it was there just reaffirms your point above about not needing it with the small cabin.
Old Jul 16, 2015 | 11:33 AM
  #47
DJS's Avatar
DJS
If you have dual-zone, there's a button on the climate screen to sync them - changing the driver's side also changes the passenger setting when sync'd. I'm guessing then changing the passenger side turns off syncing, but I can't say I've tried it.
Old Jul 16, 2015 | 12:32 PM
  #48
Nookieman's Avatar
Yes, that is what happens. I set it perfectly (synced) and my wife tries to turn on her seat heater and instead turns the knob and screws up the cabin temp. Then I go to extra features/climate and re synch it. It's essentially worthless as you say. If I could I would replace all three knobs with oil pressure, oil temperature and boost gauges, moving the climate controls to the main touch screen.
Old Jul 16, 2015 | 01:53 PM
  #49
F-typical's Avatar
Originally Posted by lhoboy
Any car purchase based on need alone will hardly ever result in the purchase of much more than a base model KIA. It's what you want versus what you are willing to pay that establishes the purchase equation.
A Volkswagen. The residuals are better...
Old Jul 16, 2015 | 02:17 PM
  #50
F-typical's Avatar
The Audis I was also considering offered active damping for ~£1k extra. At that price, I'll take them. Previous cars have had mechanical LSDs for a similar amount, so I ordered those.
£10k extra for the above is taking the Micky.
perfectson
Nov 1, 2015 10:46 AM
Get_Jaggy_With_It
Sep 25, 2015 03:09 PM
Fmf Doc
Sep 24, 2015 08:28 PM
kesslari
Sep 23, 2015 02:41 AM
JimMLiny
Sep 9, 2015 08:13 PM
