batt drain
Old Jul 26, 2025 | 10:11 AM
santacruz11's Avatar
Default batt drain
car reads low batt plz start in the past i unhooked the neg batt post and it cleared the problem . any time i change the obc it reappears , this time i unhooked the pos post , is their a difference in which post i unhook??
Old Jul 26, 2025 | 10:23 AM
DJS's Avatar
DJS
Shouldn’t matter which post. Do you still have the original battery? if so, it’s due to be replaced.
Old Jul 26, 2025 | 10:30 AM
scm's Avatar
scm
Sounds like whatever you're connecting to the OBC isn't closing the session correctly and is leaving modules in a "battery drain" state.
Old Jul 26, 2025 | 10:44 AM
new batt my dealer replace the batt a year ago and the next day it showed low batt . i disconnect the neg post and it cleared the problem until i had the smog test then it appeared again about two days later . unhooked the neg post and problem disappeared . changed my program and it reappeared and will not clear
Old Jul 26, 2025 | 01:38 PM
sov211's Avatar
CHARGE THE BATTERY! Yes, in capital letters. New batteries are virtually never fully charged on installation and yours has probably never reached full charged. Your car has been trying to tell you that it is starved for voltage! Please consider mounting and using a good battery maintainer nota battery “charger”.
Old Jul 26, 2025 | 01:48 PM
JagCode3's Avatar
Just went through this while tuning my DSP. Battery was fully charged and still got the message. Did the disconnect too.
@santacruz11 Charging won't do it - you need to reset the BMS using a bi-directional OBD2 scanner like
iCarSoft iCarSoft
https://www.jaguarforums.com/forum/f...2/#post2859858
Old Jul 30, 2025 | 10:15 AM
DaveinVegas's Avatar
I have this issue every year when I get the smog inspection. Did not disconnect the negative terminal in time this year and the battery went completely dead. Had the car jumped, drove it and put it on a battery tender and it still discharged after that. After disconnecting the battery for a short time is was fine.
yellowbandit
Jul 4, 2025 08:43 AM
Gus
Oct 3, 2021 08:04 AM
N3yyz_XJR
Sep 1, 2016 08:42 AM
haroldpeacocksr
Aug 20, 2016 05:41 PM
