battery tender
Old Dec 17, 2021 | 06:27 PM
scm's Avatar
scm
Originally Posted by yostra
Here's the installation instructions for the installation kit
Yeah, that's the one I've seen, but that one doesn't have a 12V socket.
Old Dec 20, 2021 | 05:49 AM
CJSJAG's Avatar
So, did it work plugged into the cigarette outlet??
Old Dec 21, 2021 | 07:35 PM
tzoid9's Avatar
I have never tried plugging in a Battery Tender on my '21 F type....in fact, I don't recall my car even having a cigarette lighter port. But, it does have a 12V in the cabin, I just can't recall where and my car is under raps and I'm too lazy to get it out of it's "bed". But, in most American cars at least, the cigarette lighter port (and most all the other ports) are not "live" when the ignition is off. Those few cars that do have a live port (C7 Corvettes for one), make it a point telling the owner that this a "live" port all the time...in the C7, this is where the Battery Tender is plugged in, it's worthless plugging it into the cigarette lighted port. The Battery Tender type units, regardless of whose brand, can not charge a battery thru one of those ports unless its a live port, period. To know if it's live or not, just plug in any device (phone, radar detector, etc.) with the engine off and see if its' working or charging. Chances are very high that there's no juice coming to that port until the engine is fired up or possibly put the ignition into accessory mode.
And by the way, at least in the '21 model, it's simple, simple to hook up a tender under the front hood. There's a battery charging attachment and grounding post next to the front fender shell.
Old Dec 22, 2021 | 04:17 AM
scm's Avatar
scm
Originally Posted by tzoid9
The Battery Tender type units, regardless of whose brand, cannot charge a battery thru one of those ports unless it's a live port, period. To know if it's live or not, just plug in any device (phone, radar detector, etc.) with the engine off and see if its' working or charging. Chances are very high that there's no juice coming to that port until the engine is fired up or possibly put the ignition into accessory mode.
But don't be fooled if it appears live after switching off - it may take a few minutes for things to shutdown.
That's not unique to MY21, I think all MYs have them.
Old Dec 22, 2021 | 09:32 AM
Dwight Frye's Avatar
After a lot of thought I ended up installing my CTEK tender to the bus bar terminal and grounding lug under the storage bin in the hatch. I didn't like the idea of having to open the hood to make the connection. I had some concerns about closing the hatch on the wire but the rubber weatherstrip material is thick and flexible enough that it doesn't look like it will be a problem.
Old Dec 22, 2021 | 10:39 AM
scm's Avatar
scm
I charge mine with the CTEK inside the trunk - the power cable to the CTEK hasn't caused any problems to the weatherstrip so far.
Old Dec 27, 2021 | 08:08 AM
stirlingsilver's Avatar
Originally Posted by mario41051
I did buy a battery tender and this is what I have received.
All thread I have seen, shows a battery tender with a low voltage cable that include a connector and that is wired in the trunk.
This one instead is different. Can I actually charge the battery of my 2015 F-Type R connecting this charger on the cigarette port?
Folks,
I had Norwood JLR install a Jaguar "battery conditioner" in my P300. Cost was as follows: C2P25121 charger $108, C2P25122 harness $51, labor to install $250 (yikes!). At least, I am pleased that the harness and connector installation in the trunk is tidy, and the charger seems to be working perfectly.
Before I covered the car and put it on the lift for the winter, I tried plugging the charger into the cabin cigarette lighter socket. The low battery light flashed on-off rapidly. There is no explanation for this in the instructions, so I take it to be a fault. After the car's electricals went to sleep, the flashing light went out and the tender indicated only that it was plugged into AC. So, I assume that plugging the charger into the cigarette lighter is useless.
Cheers!
Old Dec 27, 2021 | 08:58 AM
  #28
KalamazooJag's Avatar
When I ordered my new F-Type, I optioned it for the Jaguar battery tender and install kit, but it wasn't shipped with it (or the dealer didn't have one in stock when the car arrived), so the dealer purchased an after-market battery tender and hard-wired to the battery in the boot. I just plug in the cord and hang it out the boot and close the boot lid. Works like a charm.
UltraPeepi
Feb 23, 2026 08:34 PM
vet4scuba
Feb 23, 2026 03:50 PM
cloud
Dec 2, 2017 12:16 PM
06-XJR
16
Jul 5, 2016 11:13 AM
Colquan1066
Nov 14, 2013 07:25 AM
