Bluetooth OBD Reader - Battery Drain - Any fix yet?
Used a bluetooth OBD reader to get track stats for my 2016 F-Type R, and it killed my battery. Even after diconnecting the OBD tool, it continues to drain the battery.
I have read in a thread from last year that someone disconnected the battery to 'reboot' the car to stop it from draining the battery - but this needed to be done every single time you used the OBD tool. This means resaving memorized features (like radio stations, etc) every single time.
Has anyone found a fix? A workaround, or anything?
In know it is not a fix per se, but would a battery (12V 500A) switch be useful in the hot circuit, or possibly a solid state device, so that you can cycle the power without pulling the floorboards and disconnecting?
Dang...so Ihave a Bluetooth OBD reader from my previous Jag XE R Sport...no problem using it with that car. So if I were to use it with my F type, it creates a constant battery drain even after I disconnect it?
CRS
CRS
We're not certain yet whether this is a universal issue with all F-Types, but it is certainly an issue for a lot of them.
