Brake Booster
Old Aug 21, 2024 | 06:05 PM
BigJay13's Avatar
Default Brake Booster
Can I disconnect the electrical connections and remove this box?
I am trying to remove the brake booster from my 2017 F-Type SVR so that I can replace the brake pedal assembly and I need to remove this box for the little extra room. My question is…. Can I unplug and remove this box without having to have anything reprogrammed when I plug it back in? Any help is greatly appreciated so I can get her back on the road.
Old Aug 21, 2024 | 06:58 PM
OzXFR's Avatar
That "box" is the PCM (Powertrain Control module) aka ECU.
You should be able to simply unplug it (the two large electrical connectors on top) and unbolt it then remove it.
I think it might be a good idea to disconnect the battery first though.
But I know nothing about removing an F-Type PCM so it might be more complicated than that!
David84XJ6
Oct 22, 2021 08:12 PM
Ernest Knox
XJ40 ( XJ81 )
Jul 28, 2021 07:01 AM
Napa
Jan 10, 2020 05:09 PM
Rudy Mensink
Sep 30, 2019 04:39 AM
osyris
Feb 10, 2015 05:08 PM
