Brake Fluid Recommendations for the Track?
Old Mar 14, 2019 | 05:15 AM
reznik6044's Avatar
Default Brake Fluid Recommendations for the Track?
Hello All,
I'm gearing up for HPDE season and am excited to be hitting some great tracks this year. I'll be pushing my F-Type pretty hard and want to make sure I have good stopping power. I'm going to be flushing the brake fluid and was looking for some recommendations on brake fluid. Do I stay with OEM or put in something with a higher heat tolerance?
Anyone with any experience and/or recommendations?
Also, anyone know a good place to buy EBC Yellowstuff or Bluestuff in the USA?
Thanks!
-Mike
Old Mar 14, 2019 | 07:03 AM
Carbuff2's Avatar
The factory spec LV (low viscosity) DOT 4 has a decent boiling point. Long as its fresh, it should do OK.
I ran Nelson Ledges in my other car last August. NICE since the re-pave!
Old Mar 14, 2019 | 08:55 AM
SinF's Avatar
My recommendation is fresh OEM fluid, this is what I use.
Old Mar 14, 2019 | 10:17 AM
Unhingd's Avatar
+1. Stick with the specified fluid: SL.6 DOT4 (class 6) fluid. Ate is available for much less than the rebranded Jag fluid.
Old Mar 14, 2019 | 12:21 PM
Mahjik's Avatar
What are you using for tires?
The reason I ask is that tires will determine how hard you are working your brakes. Stickier tires means lower braking distances which generate more heat. The OEM tires are not that sticky so it would have to be a pretty hot day and a track with small to no straights for cooling where your fluid would be a concern. In most cases, the OEM fluid is more than enough.
ATE, as mentioned above, is a good fluid and I have used in race cars over the years. It's not as hygroscopic like a Motul RBF so you don't have to flush as often which is great for a car that is not a dedicated track car.
Old Mar 15, 2019 | 05:46 AM
reznik6044's Avatar
I typically run Michelin Pilot Super Sports, but since I've got a lot of track days this year and am looking to conserve some good will from the wife, I'm going to be trying out some less expensive tires such as KUMHO ECSTA PS91, or maybe the Yokohama S Drive.
Old Mar 15, 2019 | 09:01 AM
Mahjik's Avatar
OEM and/or ATE would be fine for most tracks in the OH area (as well as OEM brake pads). If you want to venture up to Road America, that would be a different story. I would definitely use ATE (or something in that range) along with better brake pads for a larger track like that.
Old Mar 15, 2019 | 10:09 AM
Carbuff2's Avatar
TIRES: Good things have been said here about Nitto 555s (do a SEARCH). These tires are relatively inexpensive to purchase, but wear faster.
Old Mar 16, 2019 | 10:13 PM
FType17's Avatar
Stick with the Ate DOT4 Class 6 that comes with the car. It works flawlessly on track so long as it's not old and did not absorb too much moisture.
pixel
May 17, 2018 10:17 PM
DJS
Oct 13, 2016 12:57 PM
Feffman
US Midwest
Sep 1, 2015 07:29 AM
Feffman
Motorsports
Jul 3, 2015 10:07 AM
Feffman
US Lower Atlantic
Jun 19, 2015 06:49 AM
