Brake Rotor Dimensions?
Old Jun 2, 2018 | 07:53 PM
XxMerlinxX's Avatar
Default Brake Rotor Dimensions?
Is there a thread or page with all of the brake rotor dimensions? I've searched the board to no avail, though I may just be missing it. Seems I've seen a diagram with them before, but can't recall where.
Old Jun 2, 2018 | 08:25 PM
OzXFR's Avatar
Performance brakes (standard on the base F-Type): 355 mm front, 326 mm rear.
High Performance brakes (standard on the F-Type V6S): 380 mm front, 326 mm rear.
Super Performance brakes (standard on the F-Type R, SVR and F-Type V8S): 380 mm front, 376 mm rear.
High Performance and Super Performance brakes are/were optional on both the base and V6 S.
Not sure about the 400S but I think it came with the Super Performance brakes stock, and I think the 4 potter (300PS) comes with the "base" Performance brakes stock.
Carbon fibre matrix (CCM) brakes (optional on all F-Types): 400 mm front, 395 mm rear (I think!).
Of course these are the brake rotor diameter measurements, I can maybe dig up the thicknesses later. Also, some specs quote 325 mm for the base rear brakes rather than 326 mm.
Old Jun 2, 2018 | 08:40 PM
XxMerlinxX's Avatar
I'm going to see about getting some custom rotors cast for me, so I'm looking for all the info I can find.
Old Jun 2, 2018 | 08:50 PM
Unhingd's Avatar
We just completed a group buy of custom rotors from Wortec. If you have the super performance brake option (380 fronts, 376 rears), they can build lightweight 2-piece rotors to your specifications.(+/- slots, +/- holes, hat color, disc color, round/sunburst)
Old Jun 3, 2018 | 03:53 PM
XxMerlinxX's Avatar
It was actually that thread that lead me to ask around about getting some made. I think I can pull off something similar for a bit less, just need the dimensions to get started.
Old Jun 3, 2018 | 08:00 PM
OzXFR's Avatar
OK, sounds like you need the rotor thickness measurements as well.
They are front (380 mm diameter): 36 mm / 1.42", rear (376 mm diameter) 26 mm / 1.02". Also note that the braking face on the rears starts a fair way out from the hub, ie there is a big gap, but I don't have the measurement for that gap to hand.
I'm pretty sure that to get a custom set made you would need to give them a set of the stock rotors to work from (or they could get a set themselves) and just the measurements won't be good enough.
Old Jun 3, 2018 | 08:24 PM
Unhingd's Avatar
+1.
jeremiahjaguar
Jan 17, 2013 11:13 PM
CapsLock911
Dec 15, 2008 07:54 AM
rajinder75
Oct 14, 2008 10:42 AM
H20boy
Dec 18, 2007 08:22 PM
