Can a low battery cause fault codes?
Old Aug 23, 2021 | 02:56 AM
LilyKalendar's Avatar
Default Can a low battery cause fault codes?
I hope so...
My SVR engine light (orange) turned on yesterday morning. The car has done less than 1000 km in 3 months.
I drove it for about 80 km with absolutely no issues, went to the workshop and the diagnosis reported a few error codes. O2 sensor was the most worrying, but there were other codes which made no sense, related to components that are clearly working (headlamps, audio amplifier, door locks...).
They reset the codes and the engine light didn't turn on again (40 min driving and 3 start/stop).
I will keep it under observation and try to use it more in order to prevent discharge.
Did somebody have the same issue?
Old Aug 23, 2021 | 03:36 AM
dibbyandco's Avatar
Not had this on the F Type, but had that with my XF. Low battery caused all sorts of strange messages.
Old Aug 23, 2021 | 06:01 AM
Scheffi's Avatar
Yes, this can be an issue. A low battery should be shown in the display.
Try to recharge it with a c-tek or similar charger.
Old Aug 23, 2021 | 10:11 AM
sov211's Avatar
You bet it can! And low battery voltage is one of the major causes of complaints. The fault lies is the use pattern of the car: not enough use for long enough. This is why a huge number of owners use a CTEK battery minder to kep the battery at full charge...this is not a "Jaguar thing". Every luxury maufacturer from Aston Martin to Bentley to Mercedes, to Maserati, to Bugatti...and yes, Jaguar, market the basic CTEK unit under their own brand name.
Old Aug 23, 2021 | 11:33 AM
scm's Avatar
scm
When my battery went flat every module in the car raised a fault code.
Old Aug 24, 2021 | 05:09 AM
The light is on again today
Will let you know...
Thank you all for now.
bklynchris
Jun 15, 2018 12:53 PM
JagRag
Apr 24, 2015 07:59 AM
funnyact
Sep 21, 2013 09:52 AM
Lubino Do Rego
Jun 3, 2012 11:02 AM
fclombino
Jan 2, 2009 12:10 PM
