Clear Coat Peeling
Old May 21, 2016 | 07:50 PM
ImNotFamousAnymore's Avatar
Default Clear Coat Peeling
While out and about last night I noticed a rather large amount of clear coat peeling off of the top of my front bumper (right in front of hood). It is about 3"x3" and I had never noticed it prior. I can't believe I never have seen this but it appears that it must've escalated quickly from when it started. Has anyone seen this? I've had the car for 9 months (hand washes) and find this very unsettling. I plan to take it in first thing Monday but wanted to see if any of my trusty forum friends had any insights beforehand. Also had seen forum member "Hhmaker" had a clear coat peeling at 5 WEEKS of ownership (wow).
Will get a pic up tomorrow when I'm home.
Old May 21, 2016 | 07:55 PM
Unhingd's Avatar
Was your car delayed at port when it arrived (assuming you ordered it)? Perhaps they did a bad clear coat over an improperly prepared surface to repair a transportation blemish.
Old May 21, 2016 | 07:57 PM
That's definitely worth looking into.
Old May 23, 2016 | 12:35 AM
mshedden's Avatar
My 25 year old, never garaged, totally UV exposed Nissan shed its upper surface clear coat at 24 years of age, so no, at that age - not good at all. My understanding of current paint tech is that the clear coat needs to chemically bond to the base coat (i.e. be applied close in time to the uncured base) so merely respraying the clear over cured base coat is not a great solution and will fail at some point, but I am not an expert...
Old May 23, 2016 | 01:49 AM
Unhingd's Avatar
That's exactly why it is unlikely an issue caused at the factory. Most likely, the peeling clear coat is due to a respray.
Old May 23, 2016 | 07:39 AM
SinF's Avatar
Not normal, should be covered by warranty.
Morango
May 20, 2016 11:33 AM
rtdbuild
May 11, 2016 05:26 PM
Busa
May 6, 2016 12:26 AM
Mark239
May 4, 2016 11:45 PM
xjrjag
May 1, 2016 07:24 PM
