Code p0236-22
Old Aug 9, 2024 | 12:45 PM
Doc Oc's Avatar
Default Code p0236-22
So I've been chasing a misfire for a couple days ahead of a big trip tomorrow and I've gotten to the point where there is no misfire codes, just the code listed above. Engine runs poorly, doesn't want to start, and is very rich. Seems like a vac leak but not sure where to even start. Haven't unplugged anything....
Thanks!
Old Aug 13, 2024 | 07:23 AM
BigJay13's Avatar
Just a little information that I was able to find. I'm not 100% sure because I haven't had this problem, so I hope it helps.
The diagnostic trouble code (DTC) P0236 indicates
“Turbocharger/Supercharger Boost Sensor “A” Circuit.” Your vehicle’s computer will log the P0236 code when it receives a signal from the boost pressure sensor that fails to match the expected values and will cause a rough idle and running rich. From what I can locate the sensor is located on the front left of the snout on the supercharger. This is facing the engine from the front of the car. I hope you can get it fixed and running right again.
Old Aug 13, 2024 | 07:54 AM
Doc Oc's Avatar
Thanks for the detail I appreciate it!
Biff Baxter
Jun 24, 2023 09:20 PM
KidRock'n
Nov 26, 2021 06:20 AM
GoobeGustafson
Jun 20, 2017 10:58 PM
Softball60
Aug 24, 2016 09:55 AM
Sir Arthur Streeb Greebling
Feb 9, 2015 12:46 PM
