Convertible top problem
Old Mar 25, 2022 | 07:38 AM
robbie1400's Avatar
Default Convertible top problem
My 2014 F-type has a major problem and I wondered if anyone has experienced the same or similar. A month or so ago the convertible top stopped working - absolutely no response from the switch - having worked perfectly beforehand. The fuses were all good so I tried the classic solution to everything - disconnected the battery for half an hour. Still nothing so in the end I took it to my local dealer - Jaguar in Frejus (France). They have reported that the area between the seats and the luggage compartment has water in it (car wash, rain storm?) and that this has caused certain electrical components to fail. It gets worse - this failure has also caused the roof to lock shut and it is not possible to open it without physically wrecking its latch to the top rail. Obviously this is going to result in a monumental bill hence my (first) post on the forum.
BTW I do love the car which is leagues ahead of the Aston V8 Vantage it replaced.
Thanks in advance for any help.
Old Mar 25, 2022 | 08:13 AM
scm's Avatar
scm
I've seen posts from other people who've had that water issue - the drains apparently get blocked so should be periodically cleaned through.
Old Mar 25, 2022 | 10:03 AM
Carbuff2's Avatar
Here's my 'go-to' regards 'vert drainage
https://www.jaguarforums.com/forum/f...rtible-227891/
I check the drains once a year, above & below.
Also, the recommended periodic use of a fabric conditioner on the cloth top keeps the water beading off...
Old Mar 25, 2022 | 05:23 PM
SamtheSham's Avatar
Any chance this problem has been alleviated after 2019??
Old Mar 25, 2022 | 05:26 PM
Mbourne's Avatar
Additionally there is a manual wrench underneath the passenger side footwell to open the top if I recall an earlier thread correctly. DJS has found it I think. You might want to do a thread search for that info.
Old Mar 26, 2022 | 07:06 AM
Carbuff2's Avatar
Or the Owners Manual.
(Included in the first portion of the shop manual in this STICKY topic)
https://www.jaguarforums.com/forum/f...mation-101906/
But the original statement "this failure has also caused the roof to lock shut and it is not possible to open it without physically wrecking its latch to the top rail." would make me worry.
Old Mar 27, 2022 | 01:25 AM
robbie1400's Avatar
Thanks everyone for your replies. I did a search of the forums before posting but the thread referred to did not show up.
So it looks like we'll have to replace the hood motors etc that have been water damaged. The immediate problem as I mentioned is that the top will not unlatch. Does anyone know if this can be done manually?
Old Mar 27, 2022 | 06:51 AM
CJSJAG's Avatar
https://www.ownerinfo.jaguar.com/doc.../proc/G1893594
This tells you how to close the roof manually.
I am not sure whether you can also open the roof manually.
Certainly worth a try!!
Old Mar 27, 2022 | 12:55 PM
Buckingham's Avatar
Thank you for this post. I have my top up a lot and though it hardly rains in California, I checked the drain holes. They were full of dried leaves. I quickly vacuumed them out and will do so every few months. I would also advise that anyone with a convertible check the 6 inch rid with two ball joint end on the right side top flap mechanism. This will unscrew eventually leading to the top jamming. If it hasn’t completely come out you can tigh it with a tiny spammer. I suggest using some loctite on it to slow the unscrewing.
Old Mar 28, 2022 | 07:46 AM
DJS's Avatar
DJS
There is at least one old thread of someone who had to have the locking portion cut out somehow, as it wasn’t possible to unlock it. That was more than 5 years ago, I think.
Old Aug 20, 2022 | 09:21 AM
robbie1400's Avatar
This issue is now resolved - my local dealership were at a loss as to how to deal with the problem even after consulting the factory. The solution they proposed was to dismantle the roof, completely destroying the cover in the process. However as the roof cover and certain other parts were on back order they held off for a few weeks. One day whilst moving the car in the parking area, a technician decided to try the roof again - and it worked! Having been left parked in the sun for some time the water in the roof well had evaporated and the motor had dried out. Once the roof was open, the motor could be replaced and all is now functioning properly. The invoice for the investigation, replacement motor and associated wiring harness came to nearly 4,000 euros (US$4,000). So the moral of the tale is to keep your drain holes clear.
beast dog
Jun 23, 2025 11:50 AM
mark3551
Jun 20, 2022 12:21 PM
KenFtype
May 21, 2021 07:44 PM
Baxter3319
May 14, 2021 12:42 AM
prodigy215
May 27, 2017 10:33 AM
