Coolant low issue again? Less than a year since y pipe replacement
Old Mar 27, 2025 | 05:12 PM
DJS's Avatar
DJS
Zonnie needs more posts (5 or maybe 10 total) before PMing is enabled.
Old Mar 28, 2025 | 02:54 PM
zonnie's Avatar
Originally Posted by Lavitz
tried pm'ing didnt seem to work. Do you have discord or anything I could add you.
I might need more posts to have PM enabled. Just recently joined the forums. I want to coordinate this with you with Silk. I've already spoken to Lucas on the phone. We're basically getting the exact same job done!
Old Mar 28, 2025 | 03:00 PM
zonnie's Avatar
Originally Posted by Evoex
aftermarket options available for both.
i just installed an aftermarket aluminum thermostat and an WP.
What options can you recommend for preventative maintenance?
Old Mar 28, 2025 | 03:01 PM
zonnie's Avatar
Thanks for the heads up on this. Any chance a mod can enable this sooner so I can PM?
Old Mar 28, 2025 | 07:11 PM
Evoex's Avatar
In terms of the cooling system?
x2 OEM Aluminum pipe replacements
x1 Euro Amp aluminum thermostat
x1 Euro Amp aluminum crossover pipe
aftermarket water pump
there's a few other things you may want to consider doing since the tech will be knee deep in your engine by then anyways. This depends on mileage/year and of course budget;
Supercharger Oil
Supercharger Belts
Supercharge Coupler & Isolator
Accessory Belts
Plugs
Valve Cleaning
Gearhead01
Dec 26, 2025 09:18 AM
bocatrip
Dec 24, 2023 05:35 PM
HippoCow
XE ( X760 )
Jul 19, 2023 09:02 PM
thatjagtho
XE ( X760 )
Jul 11, 2023 11:09 AM
kiphome
Sep 19, 2010 08:03 PM
