Cooled Seats
Old Dec 4, 2021 | 07:06 PM
lizzardo's Avatar
Originally Posted by lizzardo
In 2016 heated seats were part of the "Premium + Vision Pack." The temperature control knobs also control the seat heaters. Push on it and it will show a seat graphic. Rotate clockwise to go through the three settings.
Had a long drive today so looked at the knobs. The temperature knobs show the temperature and below that a seat graphic that says "Push". If you don't have that, you probably don't have heated seats (at least for 2016).
Old Dec 4, 2021 | 08:09 PM
bb_sam's Avatar
Cooled seats were only offered MY2018 onward. At a minimum the vehicle needed to have the premium leather performance seats (you couldn't get it on the base seats). As far as I know, you needed to get the heated and ventilated/cooled seats together -- for that reason, most of those wanting this option would have selected Climate Package 2 -- which would have heated/cooled seats plus the heated steering wheel and heated front windshield.
Old Dec 5, 2021 | 08:16 AM
DJS's Avatar
DJS
You can also look through the brochures to see what was offered.
https://www.auto-brochures.com/jaguar.html
Old Dec 6, 2021 | 03:53 AM
dibbyandco's Avatar
Must say I've never even thought about cooled seats - not really a requirement in the UK!
Old Dec 6, 2021 | 04:00 AM
scm's Avatar
scm
I had them on my previous XKR and used them a few times during summer. And once accidentally in the winter!
Old Dec 6, 2021 | 04:08 PM
CJSJAG's Avatar
I have heated/cooled seats in my 2021 R-Dynamic.
The leather seats are not perforated.
There are times when my wife has her seat heater on, and I have mine on cooling.
As you can guess, having dual controls was an important consideration at purchase!!
Old Dec 6, 2021 | 04:46 PM
MajorTom's Avatar
Now that's interesting. I've never seen a Jag with seat cooling without perforated seats. This is my 3d Jag with seat cooling and they all had perforated leather. Also wonder how the cooling can work without holes for the cool air to pass through. Do you have the base seats then?
Old Dec 6, 2021 | 04:51 PM
  #28
CJSJAG's Avatar
NO, Major Tom, you are right!!
They are perforated, I just checked.
Perforations are very small unlike what I have seen in other vehicles.
Had never really noticed them previously.
Sorry for the mis-information.
Old Dec 7, 2021 | 12:33 PM
MajorTom's Avatar
Ok, mystery solved then.
Old Apr 6, 2022 | 09:36 PM
  #30
soaringeaglers's Avatar
Originally Posted by eeeeek
It may be a year thing. It wasn't an option in 2016, but the controls were clearly designed to allow for them. I do have performance seats without the cooling, but mine is a 2016.
My 2016 has performance seats, but no cooling, even though the controls are made to select it.
Old Apr 26, 2022 | 09:31 PM
  #31
ViperX100's Avatar
Having read through this thread, I still wonder. Are the seats actually cooled as in AC goes through the seat/back to cool you or are they just ventilated like the ones in my C43 coupe? I have found very few seats that the manufacturer labels as "cooled" to literally cool and they just blow air instead. Thanks.
Old Apr 27, 2022 | 04:37 AM
  #32
scm's Avatar
scm
Neither. They use Peltier cells which either heat or cool depending on the direction of current flow, and fans blow the cooled/heated air through the perforations in the leather. The cooling is very effective, as I discovered in my previous XKR when I inadvertently switched to max chill while trying to turn off the heating one very chilly morning.
Old Apr 27, 2022 | 11:01 AM
  #33
kb58's Avatar
Originally Posted by scm
...The cooling is very effective, as I discovered in my previous XKR when I inadvertently switched to max chill while trying to turn off the heating one very chilly morning.
This is funny. I can only imagine you driving along, thinking, "Geez, it seems REALLY cold this morning!"
Old Apr 27, 2022 | 11:40 AM
  #34
scm's Avatar
scm
That's exactly what I was thinking! In the XKR the seat heating/cooling was controlled via the touchscreen and I hit a bump as I pressed the last button to turn off the heater - that was enough to flip the cooling onto max! Fortunately, the F-type has a proper switch to do that, so the problem is much reduced.
Feffman
Jun 1, 2021 11:28 AM
Rrosen
May 23, 2018 09:14 AM
wrd0225
Apr 25, 2017 03:16 PM
james5281
Mar 5, 2015 02:31 AM
italianjobtony
XJ40 ( XJ81 )
Dec 2, 2013 06:35 PM
