Custom Subwoofer Enclosures
Old Jun 17, 2021 | 04:39 PM
  #81
Jag Bass's Avatar
Originally Posted by Jag Bass
So while researching info on the Land rover Meridian Signature Speakers for their actual frequency response I discovered that the LR047119 200mm Woofer, LR033290 100mm Mid Range, and the LR033292 Tweeter are all 8 ohm drivers. Not that it means a lot, but I remember that higher impedance driver are better controlled by the amplifiers damping in addition to not pushing the amplifier as hard to achieve basically the same output. The speakers are produced by PSS Premium Sound Solutions. The PSS door woofers are called CDD or Coil Disc Drive Speakers.
https://docs.google.com/spreadsheets...it?usp=sharing
As an updated to this post, I believe that the information published in this spread sheet is incorrect and have reached out to the publisher to clarify the impedance values. Information taken from Topix definitely puts the 200mm woofers and 100mm mids as 2 ohms for both the Meridian 380 and Meridian Surround 770. Not able to confirm the Meridian Signature replacement drivers ohm rating on Topix but almost positive those are going to be 4 ohm drivers.
Old Jun 21, 2021 | 04:40 PM
  #82
Jag Bass's Avatar
Originally Posted by Robtrt8
Good looking install.
I've installed a couple LC 6.1200's in boats. Including in my Malibu ski boat. Tons of clean power. They do want 4 gauge minimum power wire though.
I'm curious to see what your input gain settings turn out to be. I used the Rockford 3sixty Level Set track initially and found the factory mid inputs needed to be turned up a bunch.
Went into the D-6.1200 preamp inputs with the speaker level signal. Inputs are set to 0db.
Old Jun 21, 2021 | 05:37 PM
  #83
Robtrt8's Avatar
I have the DM-810 inputs set at +9.0. I have the output on the mid (which is the factory mid plus mid-bass combined in the DSP) set to Zero. From there I’ve pulled down the sub (which is the mid-bass input) to -6, the center pulled down -6 and the tweeters pulled down just slightly on the drivers side only. I’ve done this all by ear. At some point I’ll have a chance to do a final tune with the RTA.
Driving around, 20 on the HU is above normal loud. You can still hear the exhaust with the button on. 30 is pretty loud and only clips on certain songs with big bumps.
Old Jun 21, 2021 | 05:43 PM
  #84
Jag Bass's Avatar
Default Audio Control ACR-3 Level Control
Decided to do a custom install of the Audio Control ACR 3 level control. Put it where the power port once lived and is a perfect fit.
Old Jun 21, 2021 | 06:05 PM
  #85
Robtrt8's Avatar
Very nice!
Old Jun 21, 2021 | 08:26 PM
  #86
Borbor's Avatar
Agree , nice fitment
Old Jun 21, 2021 | 08:59 PM
  #87
Jag Bass's Avatar
Now if I can just get the heliocopter out of the trunk when the active exhaust is enabled.
Old Jun 21, 2021 | 09:10 PM
  #88
Jag Bass's Avatar
At this point in tuning I am finding that inputting speaker level signal into the preamp RCA inputs, input gains are set to 0db and output sliders are used to attenuate the output as I try to target 45 on the ICT pro head unit. This is the point where the factory sub bass level stops increasing. The level of mid and high continue to increase after 45 all the way to 60. There was no clipping observed at any point.
Old Jun 22, 2021 | 04:29 AM
  #89
Robtrt8's Avatar
Oh, yeah. Forgot you were using the low level inputs. But I thought you were using the mid bass as an input for your sub?
I've played around with only using the sub channel and with using both on the input side. The factory sub just does nothing for the musicality of the system.
Old Jun 22, 2021 | 05:07 AM
  #90
Jag Bass's Avatar
Still pulling the signal from the door woofers in the DSP software and redirecting it to the preamp level output to the 1.300 the Sub woofer. System effortlessly plays down to 25Hz which is where the 1.300 subsonic filter starts to cut low frequencies. No reason at all to add accu bass feature of the AC amp. I find myself turning down the bass level more often than not, it can get that over powering., cabin gain in the car is incredible. Now just to hunt down and slay all the rattle gremlins, that going to be fun.
Old Jun 22, 2021 | 06:42 AM
  #91
Robtrt8's Avatar
Gotcha.
Bringing the rug rat back from my Volvo indy this morning, having a conversation about his overnight shift, playing the Jag’s stereo lower than I have ever played it by my self, I realized how loud the center channel still was. Pulled out the laptop and dialed back the center until it was more even with the doors at the lower level. Then played it at my standard volume and yep, that’s better.
Old Jun 29, 2021 | 04:01 AM
  #92
Robtrt8's Avatar
At times, on certain songs, the sound seems a little overmodulated on my system.
Called AudioControl tech department to ask about high level input vs low level input in our situation. He said "we cannot recommend" using the low level in our case. Did recommend using AC-LGD's.
Old Jun 29, 2021 | 04:30 AM
  #93
Jag Bass's Avatar
They are the ones that specifically told me to use the low level inputs. Right now mine is setup with -3db input gain on each of the channels with 40 being the target max volume on the ICT pro head unit. As long as your not exceeding 8vac on the inputs, should be fine. Max I was seeing was 7.30vac to the door woofers.
Old Jun 29, 2021 | 09:44 AM
  #94
Jag Bass's Avatar
Can you elaborate more on the issues you were seeing and on the use of the Load generating modules? This was never duscussed during several tech calls with audiocontrol which eventually lead me to switch from high level inputd to low level RCA inputs at their recomendation.
Old Jun 29, 2021 | 10:19 AM
  #95
TH3FRB's Avatar
Regardless of the inputs being used, it sounds like using the LGDs may be beneficial in keeping the factory amp/processor happy.
Old Jun 29, 2021 | 11:15 AM
  #96
Robtrt8's Avatar
Hard to describe other than some songs just sound put together weird. The tech said “with the highly processed system like the Meridian” it may be happier seeing a load. I figured, what the heck, I’d give it a try. The stupid part is we’re direct with AudioControl but it was easier/quicker to get them from Amazon.
1/2 of my songs are 256k MP3’s or Apple Loss Less ripped from disks. The other half are AAC’s from iTunes. Never had this problem in any of my other systems.
Old Jun 29, 2021 | 11:20 AM
  #97
Jag Bass's Avatar
While setting up the mid range channel levels I was seeing some weird wave forms on the Oscilloscope with the 200Hz test tone. I had to back off the level on the head unit down to 40 to be able to set the input gain and waveform looked more normal. Pic below.
I assume you would place the LGD's inline with each channel prior to the RCA low level inputs the same way you would with the high level speaker inputs? Also which ones are you getting, Seems like the LGD 60's are the proper units.
Old Jun 29, 2021 | 11:23 AM
  #98
TH3FRB's Avatar
Did you order the LGD or LGD60? Oddly, the quick reference from AC says the LGD60 is for 2018+ vehicles with amplified systems and the LGD is for 2005-2015 "all makes and models". I have a 2017 but assume it fits into the category with 2018+ better considering the Meridian system.
Old Jun 29, 2021 | 11:25 AM
  #99
TH3FRB's Avatar
I assume you would place these inline with each channel prior to the RCA low level inputs the same way as you would with the high level speaker inputs?
Yup. All they do is trick the factory system into thinking it's still driving the speakers directly which in theory stabilizes the signal being generated by the amp/processor.
Old Jun 29, 2021 | 12:02 PM
  #100
Robtrt8's Avatar
AC guy said I needed the blue ones.
The others are for Chrysler’s?
