Debate about the Stop/Start dual battery system
Old Oct 13, 2018 | 07:20 AM
OzXFR's Avatar
Default Debate about the Stop/Start dual battery system
A question for the tech-heads.
About Jags (not just F-Types) that have the dual battery stop/start system (ie pre 2016 when Jag switched to a single battery).
I'm having a "debate" on another forum with a 2014 XF owner who insists that the smaller secondary battery powers the starter motor for stop/start restarts (and that is it's only purpose), when I am fairly sure that the main battery is used for restarting the engine and the secondary battery's primary or even sole purpose is to power the peripherals (lights, ICE, A/C etc) when the engine has been stopped by the stop/start system. I read this somewhere, maybe on this forum, but I can't find it again.
I've also plowed through about a dozen pages in the Workshop Manual covering the batteries but nowhere does it clearly state which battery powers the engine restarts.
Anyone know for sure?
Old Oct 13, 2018 | 07:48 AM
T-Mack's Avatar
I have the small battery disconnected in my F-Type R 2014 and everything works correctly...
Old Oct 13, 2018 | 08:05 AM
OzXFR's Avatar
So have I, for the past two years and not a problem.
But that wasn't my question, what I'm trying to find out is "proof" as to which battery is used to restart the car when stop/start is working and has stopped the car.
Old Oct 13, 2018 | 08:16 AM
T-Mack's Avatar
[QUOTE = OzXFR; 1974758] Yo también, durante los últimos dos años y no hay problema.
Pero esa no era mi pregunta, lo que estoy tratando de descubrir es una "prueba" de qué batería se usa para reiniciar el automóvil cuando la parada / arranque está funcionando y ha detenido el automóvil. [/ QUOTE]
I think I do not understand you, because of my English. If you removed the old battery the Star / Stop does not work, right?
Old Oct 13, 2018 | 10:15 AM
DJS's Avatar
DJS
Your workshop manual clearly states that the small battery powers the car's electronics while the main battery starts the engine. Don’t recall where I read it, but it’s definitely in there.
Old Oct 13, 2018 | 11:30 AM
DJS's Avatar
DJS
Page 10119 of your Repair Manual. There’s a whole lot of interesting info in that section.
The primary battery is used for the engine Stop/Start. The secondary
battery is switched by the PSDB to maintain the car systems, for
example, audio, climate or lights, which are then unaffected by the
engine restart.
Old Oct 13, 2018 | 12:16 PM
T-Mack's Avatar
So what happens when we remove the small battery? I took it off just a month ago ...
Old Oct 13, 2018 | 12:59 PM
DJS's Avatar
DJS
It automatically disables the start/stop system. Not a problem, a number of people have done it.
Old Oct 13, 2018 | 01:20 PM
Carbuff2's Avatar
Has ANYONE experienced glitches in electronics due to a voltage drop during an ECO Start? (Or are we all in Dynamic mode? )
My 1980s Ford told me it was time to check the battery because the radio would 'forget' my radio presets when it got weak. And, our 2002 Dodge permanently pegs the speedometer when the battery voltage drops.
The two batteries, aren't they wired in parallel?
Old Oct 13, 2018 | 01:57 PM
DJS's Avatar
DJS
Nope, there’s some electronics in between them. And if the system detects both batteries are too low, it won’t engage start/stop.
Old Oct 13, 2018 | 02:15 PM
Unhingd's Avatar
+1. And the engine will automatically restart when it senses that the secondary battery has been depleted to a certain level.
Old Oct 13, 2018 | 02:45 PM
T-Mack's Avatar
So, when removing the small battery we also leave with "less force" the rest of the electronic things of the car? that is, we cancel the Star / Stop but also other things? so we need to have the main battery in top form, right?
Old Oct 13, 2018 | 03:58 PM
scm's Avatar
scm
All modern cars need good batteries.
Old Oct 13, 2018 | 05:51 PM
OzXFR's Avatar
Thanks DJS, dunno how I missed that bit!
Should clear up the debate on the other forum once and for all, although the member I am debating is fairly stubborn and has received written advice from his dealership that it doesn't work that way (ie that the engine is restarted by the secondary battery).
I suspect it is yet another example of the dealership "service advisor" not knowing what he/she is talking about.
Old Oct 13, 2018 | 06:13 PM
DJS's Avatar
DJS
Tell the service advisor to RTFM!
Old Oct 13, 2018 | 11:08 PM
bjg625's Avatar
Mine is dead for 2nd time, not on warranty any more. Probably pro rated. Start stop never bothered me but I don't miss it. Will not spend any real money to replace it.
clueless123
Jun 23, 2021 02:02 AM
pab
Jul 17, 2018 07:49 AM
Karl V
Jan 21, 2018 04:50 PM
NaplesTopLess
Aug 14, 2014 04:15 PM
hawaiianjag
Nov 30, 2012 06:24 PM
