The Definitive Android 10.25” Retrofit Thread
Old Nov 29, 2018 | 04:22 AM
  #141
Paul Calvert's Avatar
I think that is one of the scariest movies I have seen in a long time !
Old Nov 29, 2018 | 06:16 AM
  #142
malbec's Avatar
Scan&Translate + text grabber app will translate your manual easily.
Old Nov 29, 2018 | 06:50 AM
  #143
Itismejoshy's Avatar
Can't wait for the next chapter of this! Keep up the good work! Thanks to all involved!!
Old Nov 29, 2018 | 07:49 AM
  #144
tscjoki's Avatar
How long is the cable ?
Here you should be able to find a new one :
Amazon Amazon
Old Nov 29, 2018 | 10:10 AM
  #145
rexus31's Avatar
Originally Posted by rickw
Just spitballing here, but does the ribbon cable only connect one way? Is there a possibility to reverse it?
Old Nov 29, 2018 | 10:19 AM
  #146
tscjoki's Avatar
No, normaly it should be possible to use it in both directions if the pins on each side are the same
Old Nov 29, 2018 | 10:47 AM
  #147
I think here the bigger question is why it has destroyed 2 ribbon cables. It looks like too much current is being drawn or it is shorting. hopefully the cable burning out is protecting the daughter boards from the original. A new screen is not cheap.once again much respect for Rick leading the way.
Old Nov 29, 2018 | 10:50 AM
  #148
rexus31's Avatar
Hopefully Merryay can chime in and give some relief and guidance. It's discouraging they do not provide an instruction manual in English.
Old Nov 29, 2018 | 11:01 AM
  #149
malbec's Avatar
See my post #142. Hold the iPhone over a page and it translates any selected language.
Old Nov 29, 2018 | 11:15 AM
  #150
tassin06's Avatar
Originally Posted by xdave
The version for the X351 has been out for about a year. It has been discussed on the XJ forum recently.
XDave, do you have any details or a link to the thread? I wasn't able to find it. Thanks!
Old Nov 29, 2018 | 11:41 AM
  #151
Paul champagne's Avatar
Once frostysauce starts testing his unit, we will know if this is just a freak occurrence or an actual design flaw.
Old Nov 29, 2018 | 01:13 PM
  #152
Unhingd's Avatar
The last attempt and Carnage.... https://youtu.be/4o9MbG4o9h8
my quick diagnosis https://youtu.be/xypnFGjQLuo
Playlist https://www.youtube.com/playlist?list=PLeIUsSLmBM4kwTADK7yBxz28mwpEYYQbp
Once you get a good ribbon cable, you should try plugging all the OEM equipment back together again to see if it still works.
Old Nov 29, 2018 | 02:38 PM
  #153
355rockit's Avatar
The connector for the ribbon-cable on the motherboard looks from the video to have a lever that unlocks the cable for removal. Do you think there is a chance that one of the contacts on the connector is stuck in the down position or is misaligned which is causing it to shear the copper off the cable for that cable signal line?
Old Nov 29, 2018 | 03:00 PM
  #154
DJS's Avatar
DJS
That copper was pretty clearly burned off by excess current - not a good situation.
In general, this type of cable is called 'flex' rather than 'ribbon.'
Old Nov 29, 2018 | 03:16 PM
  #155
Carbuff2's Avatar
If you look carefully you can see that entire wire trace is charred. Not just on the end.
Could the cable have been in the wrong position when it was 'locked down'? (I would think that it would be capable of handling any current in the wire run...)
Old Nov 29, 2018 | 03:24 PM
  #156
rexus31's Avatar
It's a viable solution but for $1,200 you would think there would be an English manual. The packaging is in English, why not a manual?
Old Nov 29, 2018 | 03:28 PM
  #157
frostysauce's Avatar
Hey guys,
I wound up doing the install today. Good news is that the unit powered up. Bad news, is that I am not getting any sound or any feed from the backup camera. This looks to be just because of the lack of instructions, as with the monstrous wiring harness and no instructions, i'm not sure which things should be proxied and which things should be directly connected. The manual that was provided is purely a user guide and does not show how to plug in the units connections. I am still working on that, and once I figure out the way everything should be plugged up I will go ahead and do my install video. In the meantime, I am uploading the video for the headunit removal, and the integration of the headunit in the merryway chassis right now and those should be up shortly.
If anyone has any better pictures of what the cables connect to, and where they connect to on the harness, that would be very helpful. I've watched one of the videos in this thread where he is inserting the unit into an F-Type, but it skips some parts and then all of the sudden everything is plugged in and he's starting it up. I clearly see that the video component cable should be plugged into something, but I am just not sure what.
Old Nov 29, 2018 | 04:21 PM
  #158
Video of headunit removal;
Sorry, for some reason the video uploaded in 360p which is potato quality. Re-uploading now
Uploaded;
EDIT:
Added the guts swapover
Old Nov 29, 2018 | 06:22 PM
  #159
Originally Posted by Paul champagne
Not sure if this is the same Jenny that some of us have been talking to, but this video appears to be from her own YouTube account:
https://www.youtube.com/watch?v=vOQscP66y3Q
Going back to this, since I got the unit up and running - this is the exact interface that came with the one I received from Jenny and installed.
I'm currently unable to get the sound to work, and i'm not quite sure why that is - also, getting the backup cam working was a bit of a challenge but I figured it out (There are some supplied connectors). But, I did test and the backup cam comes on as soon as you put the car in reverse.
I have not seen anything that indicates the OEM screens will be available, this means no dynamic screen, no climate control screen, etc (Those are the only two things I used the stock HU for anyways)
Working with Jenny to figure out why I am unable to get any sound out of the system. I imagine it's because there are a ton of connectors and I am either missing one connection, or have it plugged in incorrectly (there are a few duplicate male/female connectors).
I have an install video and some initial startup footage, but because I wasn't able to get everything working properly I am waiting on publishing that. And install video is no good if I get it all wrong
Old Nov 29, 2018 | 08:05 PM
  #160
domino_z's Avatar
i really think you should post that video walking through the menus
if anything make it unlisted, and direct link it here only
