Diff oil change - reuse plugs?
Old Aug 18, 2025 | 01:18 PM
Haalex's Avatar
Default Diff oil change - reuse plugs?
Hi all,
I'm going to change the diff oil on my XE S, which has the same rear end as a base F-Type.
The workshop manual says to ditch the plugs and put new ones in. Any good reason for that? The drain plug is magnetic and costs $25..
What would you do?
Cheers,
Alex
Old Aug 18, 2025 | 02:15 PM
Dionysus's Avatar
Originally Posted by Haalex
Hi all,
What would you do?
Cheers,
Alex
No pics of the plug, but does it have a "captured" O-ring? or a captured crush washer?
If it does, that's the reason for a replacement every time. It is standard engineering practice to use O-rings and crush washers one time only. In real life, that doesn't mean the O-ring is damaged or cannot be used again, but Jaguar cannot ignore the engineering spec, in its documentation.
I've reused captured O-rings twice, but I use an O-ring lube on the ring itself as the PTFE can help to slightly swell the rubber ring. Also always use o-ring lube on new too.
Crush washers I do not reuse, only in some dire emergency.
Old Aug 18, 2025 | 04:04 PM
lizzardo's Avatar
I'm pretty sure they're tapered thread. I reused mine, and if the drive hole isn't damaged would reuse it without a second thought. I'm not sure the rationale for replacement.
Old Aug 18, 2025 | 04:08 PM
Dionysus's Avatar
Yeah, if it is a tapered pipe thread, agree, does not need replacement. Wouldn't be a second thought on my part as well!
Lothar52
Jan 11, 2025 03:30 AM
Givoo
Aug 19, 2023 05:51 PM
Jeff Morris
Jul 25, 2023 11:40 AM
Roger95
XJ40 ( XJ81 )
Apr 21, 2022 10:12 AM
2004XJ8
May 29, 2020 02:28 PM
