Differential replaced @ 26488 miles
Old Sep 16, 2017 | 03:25 AM
jaguny's Avatar
Is there a longer warranty than standard coverage (60 months for MY 16 in USA) for rear diff? I only drive 5-6k per year on the car. Sounds like this could be part defect and it's only an matter of time and mileage, although some failures seeming to happen at low mileage.
Old Sep 16, 2017 | 10:08 AM
SinF's Avatar
Originally Posted by Queen and Country
So what are we suspecting the cause of this trouble.
Two possible causes I think is insufficient damping in the driveline. While I never intentionally tried, I bet I could kill diff in F-type under an hour power shifting on track.
Old Sep 16, 2017 | 01:30 PM
Unhingd's Avatar
+1. Particularly with the MT, it would be easy to quickly abuse that tiny diff into a pretzel.
Old Sep 18, 2017 | 07:17 PM
frank james's Avatar
Is this a problem with all years and models ? I have a 15R
Old Sep 19, 2017 | 10:16 AM
DPelletier's Avatar
Well based on this thread;
- V6S mechanical diff; three failures 2014,2014 & 2016
- V8S/R Electronic diff; three failures 2014, 2014 and 2016
I'm not aware of any changes year to year
Dave
Old Sep 19, 2017 | 10:30 AM
Kief's Avatar
- V8S/R Electronic diff; three failures 2014, 2014 and 2015
Dave
OP, Has a '16 R
https://www.jaguarforums.com/forum/f...9/#post1448196
Old Sep 19, 2017 | 08:43 PM
Unhingd's Avatar
Dave
Apparently, anything with either type of LSD.
Old Sep 20, 2017 | 01:22 AM
  #28
Misujerr's Avatar
That's just great...
Thanks for the summary DPelletier!
Old Sep 20, 2017 | 05:28 AM
jaguny's Avatar
Any info on length of warranty coverage for this?
Old Sep 20, 2017 | 06:41 AM
  #30
Unhingd's Avatar
Same as the rest of the car.
Old Sep 20, 2017 | 07:03 AM
  #31
slojotaa's Avatar
The R-Dynamic will have an old-school mechanical LSD. Play in the snow all you want. It's the V8R that has the eLSD.
Hi Un
Can you explain for me. I am a bit confused. Does the 2016 F-Type R have the one that is prone to problems, or the one that is not? Thanks I am just a bit confused reading the thread.
Old Sep 20, 2017 | 07:18 AM
  #32
Kief's Avatar
Originally Posted by slojotaa
Hi Un
Yes, 2016 are affected. OP of this Thread has a 2016 R.
Old Sep 20, 2017 | 12:46 PM
  #33
Unhingd's Avatar
Hi Un
The electronic limited slip diff in the R will overheat under track conditions and a number have failed as a result. They will also fail if overworked in snowy conditions.
The mechanical limited slip diff in the V6S and R-Dynamic has also failed a number of times with broken spider gears. The open diff on the base models seems to be the only reliable one.
Old Sep 20, 2017 | 03:29 PM
  #34
FR500GT's Avatar
We'll see how it holds up at Chuckwalla next month.
Old Apr 11, 2020 | 08:21 AM
  #35
Terrance39's Avatar
What is considered "high temp" for the diff?
Old Apr 14, 2020 | 12:25 AM
  #36
ahmad.366's Avatar
had some grinding noise a while back, took it to the agent, they told me it was the propeller shaft, and it was replaced under warranty. Also, I had the differential assembly redone as well, around 18 months ago.
Glad i extended my warranty, yesterday Jaguar Middle East told me that they have stopped selling year 6-7 warranties in the Region.
