dip mirrors. Don't dip
Old Mar 1, 2015 | 10:04 AM
johney5's Avatar
Default dip mirrors. Don't dip
I have the option to set my mirrors to dip on the dash menu, but my mirrors do not dip in reverse. Is this feature an additional option? Or am i doing something wrong to get them to work...i severely miss this feature.
Old Mar 1, 2015 | 10:59 AM
kingkong79's Avatar
Did they ever dip before?
If not when you put it in reverse, you need to set the mirror to where you like it and save it to the seat memory position. Then it should dip to that position everytime.
Old Mar 1, 2015 | 11:10 AM
Foosh's Avatar
Seat memory and auto-dip were options bundled into one of the expensive packages in '14-'15 base cars. I don't think you could order those a la carte.
Old Mar 1, 2015 | 11:44 AM
DJS's Avatar
DJS
It (right mirror only) undips if you go more than 5MPH in reverse, but I doubt that's the issue. When it's in the dipped position, you can adjust its position, which will be remembered next time it dips. Perhaps the dipped position is adjusted nearly the same as the undipped?
With auto-dip on, put it in reverse, adjust the right mirror, then take it out of reverse. See if it moves.
Old Mar 1, 2015 | 09:11 PM
Mulmur's Avatar
On my F type R it dips.. and it can be programmed not to.
Lawrence
Old Mar 1, 2015 | 09:21 PM
allenman85's Avatar
As the others have said...
1) Make sure feature is enabled (via touchscreen)
2) Put car in R
3) Adjust RIGHT mirror down while in R
4) Go to D; Right side mirror should return to its original position. You can readjust at this point
5) Go have fun!
Old Mar 4, 2015 | 08:33 AM
johney5's Avatar
called jag service. waited for them to call me back. went back and reread the Manuel...discovered by pushing the right and left mirror buttons together the mirrors retracted...and guess what? after doing this once my mirror now dips. Hallelujah. Service calls me back at the end of the day...(busy with a customer, for 8 hours.) and tells me he's not sure if my car has dip mirrors (he has my build sheet), but if i did retracting the mirrors would cause them to reset and then they might work. Thanks.
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Richard_gib
Sep 12, 2015 07:08 PM
giandanielxk8
Sep 6, 2015 07:21 PM
laserguy
Sep 3, 2015 02:02 PM
dcvickers
Sep 2, 2015 06:14 PM
