Do I need to replace SC Snout now..?
Old Aug 6, 2022 | 04:15 PM
Iticip's Avatar
Default Do I need to replace SC Snout now..?
Hello fellow enthusiasts,
I have a 2015 F-Type R that sometime in the last ~5,000 miles had the supercharger coupler issue come about. I can hear the uneven light noise at idle. I feel confident this is the issue.
Unfortunately I'm 23 and YOLO'd into this car purchase (absolutely no regrets whatsoever) and a ~$1,000 expense is not ideal right now, as I get paid on an annual basis and didn't get paid for last years work (will get paid big money for this year).
I see no engine lights and notice no impact on driving. I'm wondering if I can get over the January pay day hump, or if I'm risking engine/SC failure before then.
Can I wait another 6 months and ~5,000 miles before getting it done, or is this something I need to get done before the whole bearing gets worn down and snaps, causing a SC failure? Driving back to Texas from NY in a little over a week.
I appreciate any insight. Thank you.
Old Aug 6, 2022 | 04:29 PM
kb58's Avatar
I'll refrain from any fatherly lectures, but it's not easy. Short answer: You'll very likely be fine.
Old Aug 6, 2022 | 07:34 PM
OzXFR's Avatar
If the rattle only started some 5,000 miles ago you should be fine for a while yet, as kb58 said. Many around here have driven their car 10s of thousands of miles with a rattling SC coupler with no major problems.
IMHO once you get to 40 or 50k miles with the coupler rattling you can then expect problems. What happens is the coupler spring wears a big groove in the SC shaft which causes it to become unbalanced, and this in turn causes excessive bearing wear which in turn can damage the SC.
Old Mar 24, 2023 | 03:26 PM
no1's Avatar
no1
I just took the nose off to replace the coupler while doing an oil change and was met with this ugliness. Are those grooves far enough alomg that this will now need to be replaced right away or did i catch in time?
thank you for any insights u have on this issue it is much appreciated
Old Mar 24, 2023 | 07:12 PM
OzXFR's Avatar
I can't add anything from personal experience but those grooves look pretty bad to me and I reckon it's time to replace the snout (including shaft and coupler).
And thanks for posting up the pics so others can see what a worn/grooved SC shaft looks like.
Old Mar 24, 2023 | 07:46 PM
u102768's Avatar
Couldn't you use a solid coupler as they just slip over the shaft and don't have a spring? I have had one on my XKR for over 4 years with no issues.
Old Mar 24, 2023 | 08:33 PM
DJS's Avatar
DJS
With the caveat that, like Sgt Shultz, I know nothingk! - I’d wonder where the missing material ended up, and I’d worry about it not being balanced anymore.
Cwis
May 20, 2022 07:03 PM
XxSlowpokexX
Feb 27, 2022 08:03 AM
Shack9
Nov 25, 2021 07:48 AM
2MSTONE
Aug 20, 2016 03:41 PM
Tandemcha
US Lower Atlantic
May 2, 2016 11:14 AM
