Does anyone have the patience to fabricate something like this
Old Aug 23, 2016 | 01:37 PM
polarisnavyxj's Avatar
Default Just found this...could be a fit.
https://www.rockwestcomposites.com/r...n-tubing/45658
Would like to go halves with someone perhaps as we only need 9" per pipe (thats what she said) for a total of 36" (4 pipe V8) as they come in 72" lengths. Anyone?
I requested a sample for a test fitting but based on the ID, it may very well be a nice easy press fit that slips on with a little silicon on the end. Super simple.
The 3.5" ID version they also have would leave a nice reveal gap between pipe and carbon but adds the issue of centering the carbon around pipe. We would need some form of spacing which probably wouldn't be worth the extra hassle.
Old Aug 23, 2016 | 07:53 PM
Unhingd's Avatar
Originally Posted by polarisnavyxj
Unhingd, I gathered you would have strong personal feelings about the project. We have to accept that everyone has different objectives....remember? I'll PM him.
No strong feelings at all if it's on your car, and I'll do what I can to assist you in implementing whatever mods you want to undertake on your car. I'm just ambivalent about CF (for appearance purposes) and understand that makes me an outlier among auto enthusiasts.
Old Aug 23, 2016 | 07:59 PM
Unhingd's Avatar
Not looking promising
Round Carbon Fiber Tubes
The OD of our tips (V8) are about 3.25"
Unfortunately, the smallest tube in that list that would fit over the OEM tube has a 4.25" ID and would require a half inch spacer all around. Ideally you could find a tube with a 3.375" ID.
Old Aug 23, 2016 | 08:06 PM
I think your dual pipes are bigger than the quad. I thought ours were 3.25" but I didn't use calipers to measure just a tape with eyeball.
This is the list we are referring to: https://www.rockwestcomposites.com/r...n-tubing/45658
That other company has nothing that will work. They have since sent me an email stating that they send out no samples so it's a dead deal.
I am going to get some aluminum tubing and wrap it black carbon to match what I have.
Old Aug 23, 2016 | 08:09 PM
Unhingd's Avatar
If the press/slip-fit works with the 3.25 ID sample, leave it on the car for awhile and get the pipes to full temp to see if the heat expansion of the metal tips split the carbon fiber. Don't try to wack it on with a hammer, but rather cool down the tips with ice packs before sliding on the CF tube.
Old Aug 23, 2016 | 09:19 PM
lizzardo's Avatar
Did you check the links I provided?
Old Aug 23, 2016 | 09:28 PM
Unhingd's Avatar
No, I was looking at the one Polaris first provided. Obviously, just about any size is provided. Now to determine how best to fuse the tube to the tip, given the large temp fluctuations.
Old Aug 23, 2016 | 09:40 PM
  #28
They won't send me samples as I said as the cf is outside of their sample policy. The tubes are far too expensive to experiment and gamble with so as I said earlier, I am just going to wrap aluminum tubes with black cf wrap to match whats already on the car. I can't even see the color of the carbon other than the pics online. Its probably basic silver weave whereas my wrap is black which will clash hard.
With the aluminum tube, I don't have to worry about failure. By the way, earlier today I drove the car hard then touched the pipes after I got home and they were cool enough to keep my hand on. I would describe as very warm, not hot. I'm not sure they even get as hot as we may be thinking.
All I really need is to get the pipes scalloped, I'll wrap them myself. Anyone have the skill to just do that if I send you the four 9" pieces? I guess I can find a local machine shop.
Appreciate the good ideas though.
Old Aug 24, 2016 | 07:43 AM
Unhingd's Avatar
The V6 pipes may be different. I know my wrap has bubbled just above the pipes when the car was mounted to the dyno, and I remember an early post from someone who was burnt badly by brushing up against the center pipes while wearing shorts.
Old Aug 24, 2016 | 09:28 AM
  #30
DJS's Avatar
DJS
Aluminum has a higher coefficient of thermal expansion that steel/stainless steel, so it could get loose at high temp.
Old Aug 24, 2016 | 11:14 AM
  #31
enderle's Avatar
I'm dying to see if there is a final solution as I'd like to change the tips on my car. You might check out startech they apparently were working on tips for our car. Not clear what the material is (everything else seems to be carbon fiber). Startech customizes Jaguar F-Type with leather and carbon for Geneva auto show | Autoweek
Never mind, they are black, but interesting treatment: Jaguar Tuning from | STARTECH Refinement
Old Aug 24, 2016 | 11:22 AM
  #32
SinF's Avatar
I'd hazard to guess that active exhaust in open configuration combined with hard driving will heat up tips.
Old Aug 24, 2016 | 01:05 PM
  #33
Unhingd's Avatar
What other scenario is there?
Old Aug 24, 2016 | 01:12 PM
  #34
SinF's Avatar
Rumor has it, green F-type was seen driven under speed limit in the right lane in a quiet mode. With a turn signal blinker constantly engaged. After such unjustifiable abuse exhaust tip temperature could be alarmingly low.
Old Aug 24, 2016 | 01:51 PM
  #35
Unhingd's Avatar
My wife must have taken it out for a drive without telling me! lol
Old Aug 24, 2016 | 02:27 PM
  #36
When I said hard driving, I meant zipping up and down the street like 50 for a while at high revs to see how hot the pipes got. I'm sure they can get hotter but for what I do I got the info needed.
Old Aug 24, 2016 | 06:02 PM
  #37
Uncle Fishbits's Avatar
This gent has some carbon fibre tubing, slightly used, cheap!
Old Aug 24, 2016 | 06:14 PM
  #38
Mbourne's Avatar
Its a duration thing as well. After driving for an hour or two in spirited mode...ok normal for me...the tips on the quads of mine get very hot. After one such trip I opened the trunk to get plastic bagged groceries out and realized i had a extra bag that fell down and landed on the tip. It melted almost immediately and of course smelled awful. Had the wait for them to cool down an hour later to get the polish out to clean off the burned/charred plastic.
Old Aug 24, 2016 | 06:28 PM
  #39
enderle's Avatar
Better by far than what happens when you are in shorts and touch the tip with your leg. Did that on bailer when I was young and had to stay out of pools for most of the summer (which really sucked). Oh, and it didn't hurt when it happened but as soon as anything touched the place where skin used to be it hurt insanely.
Old Aug 31, 2016 | 10:20 AM
  #40
enderle's Avatar
Was on the Paramount site, they have fighter jet tips they sell with their high performance tune but you can buy them separate. Another alternative: https://www.paramount-performance.co...haust-Tip.html
