Does Anyone Track Their F-Type?
Old Feb 24, 2018 | 08:04 PM
alrivers's Avatar
I go out with SpeedSF to Laguna, Sonoma, Thunderhill and Buttonwillow here in CA. I have a BDE V6s and love how tossable it is; however, the Pirelli's dont like the abuse nor do they inspire much confidence on high speed turns. I'll be swapping to the Michelins soon!
Old Feb 24, 2018 | 08:42 PM
IlMostro796's Avatar
Nice blue BDE. I have a white one. I think I had a chat with you on instagram a few months ago. I echo your sentiments about the car/tires.
Old Feb 24, 2018 | 08:47 PM
alrivers's Avatar
Yup! Loved the pics of your COTA track day
Old Feb 24, 2018 | 08:54 PM
Thanks. I’m going back to COTA in a few months. I’ve gotta figure out a better tire strategy though. Not sure I can do another 2 days on the same set of Zeros I have now. But there’s plenty of “street” life left in them. I think I need to get a set of 19s with michelins for track use, because if I don’t, prematurely swapping 20” tires might get a bit stupid expensive.
Old Feb 24, 2018 | 10:19 PM
FR500GT's Avatar
Nice man! It’ll be my first time at Thunderhill in a couple of weeks (March 10th and 11th). Are you still using the stock pads?
Old Feb 25, 2018 | 02:47 AM
alrivers's Avatar
Yep, the upgraded stock pads and rotors. They did pretty well as I didn't notice any fade even after 7 fun cat and mouse laps with a moded E46 M3. Are you doing Thunderhill East or West? ...or the Thunder-schleife? 😮
Old Feb 25, 2018 | 07:59 PM
FR500GT's Avatar
Unfortunately not taking the F-Type this time, actually just going with my brothers track prepped E46 M3 for support. Which one do you like better; East or West?
Old Mar 4, 2018 | 03:52 PM
  #28
I just signed up for another HPDE at MSR Cresson, outside of Dallas. Has anyone ever driven that track before? It's the 3.1 mile loop.
Old Mar 5, 2018 | 02:11 AM
zmoothg's Avatar
Originally Posted by Mahjik
The F-Type is more of a GT car so it's heavy. It has a typical street alignment which will understeer if you drive it hard.
Understeer??? Maybe our cars are setup different but I get oversteer if anything
Old Mar 5, 2018 | 07:07 AM
  #30
Unhingd's Avatar
+1. Never get any understeer, just oversteer under power.
Old Mar 5, 2018 | 07:23 AM
  #31
4x4uk's Avatar
+1 oversteer under power
Old Mar 5, 2018 | 01:27 PM
  #32
Unhingd's Avatar
Just got to thinking...my car's been lowered and the camber is set just beyond the factory recommended range and has far less roll than factory setup. That would account for the more neutral steer.
Old Apr 1, 2018 | 02:41 PM
  #33
Peter Gheeraert's Avatar
Default V6S RWD
I take my FType Coupe V6S to the track about 3 times per year. It’s fun to drive and faster than stock 911 Porsches... Surely in the wet it handles fabulously!
Swapped the P Zero’s to Michelin and the front brake pads to EBC Yellow stuff. Rear and front brakes are the high performance versions.
Before the trackdays I remove all excessive weight from the trunk, like the tire repair fluid and pump and the little tray underneath the trunk cover. Next time I will also remove the start stop battery and engine cover.
Today i’ve orderd the VelocityAP ECU update so next track day should be extra fun.
Tires and brakes are to be replaced after about 3 track days.
Old Apr 1, 2018 | 03:08 PM
  #34
FR500GT's Avatar
How do you like the EBC pads? The Michelin PSS’s definitely were an improvement over stock and now I look forward to testing out my new 4S’s.
Let us know your feedback of the VelocityAP tune on track as I have been curious about this for the past few months now. I don’t think anyone has tracked on a pulley/tuned V6 yet and I’m itching to do it this summer.
Old Apr 1, 2018 | 03:35 PM
  #35
The Yellow stuff brake pads are fine, had zero fade but it was a cold day with rain half of the day. They get better when hot, so for street use they require getting used to. Did you compare the PS4S to the new P Zero Corsa line?
i did not order the pulley yet, will start with the ECU remap first. I should be able to compare on the track with or without the tune because I can reprogram in the pit lane...
Old Apr 7, 2018 | 04:09 PM
  #36
Matttheboatman's Avatar
I stayed with OEM pads - certainly the week link on the F-Type, but as others have said - the AWD is truly an amazing car. I think the ideal tire set-up is Michelin Cup 2s, 265 on fronts and 305s rear. If the car was 300- 400#s lighter it would be world-class track car. But, I find her very capable with the better tires.
I've been working on my left foot braking and keeping the OEM suspension balanced all the way thru to the apex. The car has all the power, she just needs to be managed a bit to the apex and on the way out.
Old Apr 7, 2018 | 07:18 PM
  #37
lizzardo's Avatar
If it were 600 lbs lighter, I'd never come into the house.
Old Apr 8, 2018 | 07:54 AM
  #38
SinF's Avatar
If it were 600 lbs lighter, 10% faster, and free then I'd just make love to it all the time and never go anywhere.
Thankfully, it is not.
Old Apr 8, 2018 | 06:01 PM
  #39
lizzardo's Avatar
If it were 600lbs. lighter, it'd probably be 10% faster (depending on how you measure "faster").
Old Apr 9, 2018 | 03:26 PM
  #40
SinF's Avatar
The only reasonable way to measure fastness is with a butt dyno.
