Driver’s console stuck on “Auxiliary Selected “ after battery change.
Installed a new battery and took care of all but one post-change item - the center of the driver’s console is stuck on “Auxiliary Selected .” I’ve tried a number of fixes including:disconnecting the AUX Source, cycling the media source, and performing a complete power drain (disconnecting the negative battery terminal for 30+ minutes). I also tried to force an Infotainment Soft Reset but it wouldn’t turn off using the center console mounted volume control. Any and all additional suggestions would be greatly appreciated! Thanks.
