Driver side window loose?
Old 04-23-2022, 10:42 AM
dwilk's Avatar
Default Driver side window loose?
Hey everyone,
It appears that my driver side window has become loose. It moves much easier than the passenger side (which maybe is attributed to me rarely opening that door?) and squeaks.
What holds the window in place? How can I tighten this to alleviate the issue?
Old 04-23-2022, 02:03 PM
Unhingd's Avatar
Received 4,652 Likes on 3,362 Posts
Originally Posted by dwilk
Hey everyone,
You’ll have to pull the door card.
Old 04-23-2022, 03:23 PM
dwilk's Avatar
Thank you for your response. What do I need to do after I get the door card off (or what do I need to look for)
Old 04-23-2022, 08:17 PM
Unhingd's Avatar
I suspect a nut has loosened attaching the track to the door.. Just check all the fasteners.
dwilk's Avatar
sounds easy enough, thanks!
Old 04-24-2022, 01:55 PM
dwilk's Avatar
I tightened everything I could and it didn’t make a difference. There were some metal clips I saw that I adjusted, which made a minimal difference. I think the problem might just be caused by more usage of the driver side door vs passenger.
Old 04-24-2022, 02:05 PM
kb58's Avatar
You should at least be able to figure out why it's loose. Wiggle the glass and see what bracket is not firmly attached to the glass and go from there.
Old 04-24-2022, 07:50 PM
Unhingd's Avatar
+1.
Old 04-25-2022, 12:29 AM
dwilk's Avatar
Trust me, I tried, but all I could see were the little metal clips. Nothing adjustable at all. It’s possible it was further in the door but I’m hesitant to go further in fear of breaking something. At this point I’ll just have to learn to deal with it.
Woodrun
09-18-2018 10:51 AM
02silver_x-type
12-22-2014 07:45 PM
tibam13
11-04-2014 04:10 AM
Red Mist
11-13-2008 05:38 PM
Quick Reply: Driver side window loose?
